Slow upload
peterb99
Slow upload
Hi all,
I've been with Plusnet nearly a month and am happy with it.
I was supposed to get 53meg but I only get 40meg. I've checked the BT test and my IP profile is 40meg so that seems ok.
However, the upload is really poor, I was estimated at 15meg but only get 5meg - the IP profile shows 20meg. Surely I should get faster than 5meg?
This is using a PC directly connected to the router via Gig ethernet.
1 REPLY
Re: Slow upload
Hi peterb99,
I've checked your connection and that is the speeds your modem is syncing at, I'd suggest running through the checks at http://faults.plus.net and if there is no difference we can look into it from there.
