turn on suggestions
Slow upload speeds
- Slow upload speeds
Slow upload speeds
Slow upload speeds
30-05-2014 3:56 PM
Is there any way to improve my upload speeds? Right now I'm getting quite an abysmal 0.3 - 0.4 Mbps upload, which is really affecting VoIP and Skype calls, and even FaceTime on the iPhone. I am able to see the other party and hear them clearly, which indicates that download is not a problem, but they will always not be able to see or hear me. Is there a way to improve the upload speeds or remove the upload cap? Thank you.
Jackie
Jackie
1 REPLY
Re: Slow upload speeds
30-05-2014 4:01 PM
Unfortunately your upload speed is already uncapped but only syncing at 672kb/s, which explains why you're not seeing great throughput speeds.
Are you connected in to your master socket and is there any noise on the phone at all?
Chris Parr Plusnet Staff |
