Slow upload speeds
- Re: Slow upload speeds
Slow upload speeds
17-12-2013 9:53 AM
I have just notice that my SN Margin on my upload is very high 30,4 compared to standard target of 6bB?
Also, I have noticed from reading this forum that Plusnet cap the upload speeds. How do you get the upload uncapped?
17-12-2013 2:02 PM
18-12-2013 11:24 AM
Testing today looks promising. My upload has gone from 0.22 Mbps to 1.12 Mbps and the is now at 5,8 instead of 30 db. (SN Margin (Up/Down) [dB]: 5,8 / 6,4)
Really appreciated,
Matt
02-01-2014 7:31 PM
i too have slow upload speeds (0.36), can i have this uncapped please?
cheers
02-01-2014 10:22 PM
Thanks.
03-01-2014 10:40 AM
04-01-2014 9:56 PM
13-02-2014 6:03 PM
Can I request an uncap?
06-05-2014 9:31 PM
the upload speeds seem to have reset to lower levels on my account.can these please be uncapped again.
thanks
07-05-2014 4:41 PM
@sunshine118 - I've just reset your line which should push your upload speeds back up, let us know if it creeps down again.
07-05-2014 6:50 PM
still seeing slow upload speeds. you said you've reset my line, does that mean you've un-capped my upload speeds?
cheers
08-05-2014 9:14 AM
19-05-2014 9:03 PM
upload is back down .014. also just had all wireless shut down for a bit and all direct line connections redirect to the router login. i have a technicolor tg 582n,
any help please
cheers
20-05-2014 10:00 AM
I've had a look and your line is erroring very frequently. Your upload speed is still uncapped, however, we need to figure out the reason your line is erroring.
Can you please raise a fault here: http://faults.plus.net
Our Faults team can then investigate this for you and provide any updates.
02-06-2014 9:17 AM
openreach engineer has been round and there is no problem on their end of things. my upload speeds are still low.
can we double-check that the line is at least uncapped to 1 mb for uploads please.
Alternatively could you send me through a new router as this looks like the only other reason for the low upload speeds or connection issues
cheers
