Slow upload speed
amuke
Slow upload speed
Hi I've got a TG582n router, and I've noticed video uploads to youtube / uploads to dropbox being painfully slow.
I've provided information alluded stated on this post: http://community.plus.net/forum/index.php/topic,96155.0.html below:
Link Information
Uptime: 0 days, 0:42:04
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 443 / 15.355
Data Transferred (Sent/Received) [MB/MB]: 83,24 / 463,68
Output Power (Up/Down) [dBm]: 11,9 / 0,0
Line Attenuation (Up/Down) [dB]: 13,0 / 26,0
SN Margin (Up/Down) [dB]: 30,9 / 6,2
Loss of Link (Remote): -
Error Seconds (Local/Remote): 42 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 46
HEC Errors (Up/Down): 0 / 644
BTW Performance
1. Best Effort Test:  -provides background information.
Download  Speed
12.55 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 12.55 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 13.55 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
0.18 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.18Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
Any assistance greatly appreciated!
Luke
Fixes: 123
Re: Slow upload speed
Looks like you may need to raise a ticket requesting your upload to be uncapped.
Customer and Forum Moderator.
amuke
Thanks Strat, I've done that and will post the outcome!
EDIT: I've been informed that in 5-7 working days I will be uncapped - if you don't hear any more from me here in the next week, it worked!
This should complete tomorrow for you.
Hopefully we won't hear from you  Grin
Chris
