Slow upload speed
steveuk75
Slow upload speed
Merry Christmas everyone.
I've been with Plusnet over a month now and I guess my connection speed has stabilised.
Using the BT Speedtester I get the following result:
Download speedachieved during the test was - 4058 Kbps
Additional Information:
Your DSL Connection Rate :6176 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 5000 Kbps
I am actually happy with download speed achieved but my problem is the upload speed. Whenever I do a speed test, e.g. speedtest.net or broadbandspeedchecker.co.uk the upload speed is shown as 0.05Mbps or 57Kbps or something of that level. Is that normal? It feels very slow and causes problems when video calling, for example, plus uploading pics/vids is a bit ... painful.
Is there anything I can do to improve that?
Thanks,
Steve
Re: Slow upload speed
The BT speedtest should have tested the speed up and down but you have only shown the down speeds... what did it say for up?
Fixes: 71
I think upload tests are done only for 21CN/ADSL2+ connections, and this appears to be 20CN/maxADSL.
The upstream sync speed (448kbps) is correct but the measured speed should be 350-380kbps, so your result is very poor.
What stats does your router give? Copy/paste data from this page if you have a Thomson TG585 supplied by Plusnet.
David
steveuk75
Link Information
Uptime: 0 days, 4:11:33
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,044 / 6,880
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,784
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 22.62
Output Power (Up/Down) [dBm]: 12.0 / 20.0
Line Attenuation (Up/Down) [dB]: 20.5 / 35.5
SN Margin (Up/Down) [dB]: 23.0 / 12.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Signal (Local/Remote): 4 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 226 / 0
FEC Errors (Up/Down): 2 / 127,451
CRC Errors (Up/Down): 0 / 176
HEC Errors (Up/Down): 0 / NA
I hope that makes sense to you. I'm surprised that the data sent is 0Kb!
Thank you in advance.
Steve
Fixes: 71
Nothing obvious to me there which might explain such low upload speeds, in particular large values of CRC or HEC errors. Error seconds is high (226) which is 1½% of up time, but that wouldn't explain such a large slowdown. For reference my value is 23 after 144 days up time.
Plusnet's own speedtester is at http://www.mybroadbandspeed.co.uk/. Downstream speed is low for me at the moment, but upload is around 350kbps.
Getting 0.00 kB for Data Sent is normal on this router, nothing to worry about.
David
steveuk75
Thanks for the quick reply :-) Strange!
I just ran that test
Fixes: 62
Try disabling your antivirus/firewall and try the test again
Fixes: 71
Just seen a post elsewhere that reminded me of something - is your connection to the router wired or wireless? If it's wireless upgrading the router's firmware to 585v8 version 8.2.7.8 firmware (Plusnet branded) might help.
See Community Library Article for instructions.
David
steveuk75
No firewall/antivirus to disable. I'm using MacOS. (Unless there's a firewall built-in?).
I'll try upgrading the router software. Currently on Product Name: TG585 v8    Software Release: 8.2.7.7
Thanks,
Steve
pierre_pierre
from the V8 thread, PN have to do the upgrade from their end on Macs
Quote from: Joanne
HI all,
The updated firmware is now on the community library (585v8 version 8.2.7.8 firmware/ updated wi-fi drivers) I'd be interested to hear if this solves any Windows OS issues as we know it was successful for mac, so please let me know. There is currently no facility to download this on mac OS but Bob has left a suggestion in a comment at the bottom of that page. Alternatively if you have a Windows OS device you could use that to do it.
Jojo Smiley
ps we will still upgrade mac users remotely if requested
jojopillo
Hi steveuk75,
The firmware upgrade has fixed an issue with slow upload but it wasn't as slow as yours. It still probably the first thing worth trying though. If you don't have a windows machine you can use to upgrade then let me know and I can get it upgraded remotely for you.
Jojo Smiley
steveuk75
Yes, please, if you could do it remotely that would be great. No access to a windows machine until early Jan.
steveuk75
Thanks for the update, Jojo, my router is now running the latest version. Unfortunately the upload performance hasn't improved much :-( 4576kbps/52kbps at the moment.
Current router stats:
Uptime: 0 days, 10:21:02
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,032 / 6,944
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,880
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 89.29
Output Power (Up/Down) [dBm]: 12.0 / 19.5
SN Margin (Up/Down) [dB]: 23.0 / 11.5
FEC Errors (Up/Down): 2 / 1,064,441
CRC Errors (Up/Down): 3 / 707
HEC Errors (Up/Down): 5 / 7,013
Any suggestions?
Thanks,
Steve
jojopillo
HI steveuk75,
I didn't do anything. Is your firmware version 8.2.7.8?
Jojo Smiley
steveuk75
Well, you're so good you just have to think about it and it happens (or it could be the support case I raised Shocked) ).
Yes, the release is 8.2.7.8. Upload speed is right now 107Kbps which is double what I was getting previously. I hope it remains at least at that level. What is a realistic speed I should expect?
Thanks,
Steve
