Slow upload speed
- Re: Slow upload speed
Slow upload speed
05-01-2015 5:30 PM
05-01-2015 5:36 PM
If you post your router stats we should be able to tell what your situation is. If you are using a Plusnet supplied router this will give the required information: http://192.168.1.254/cgi/b/dsl/dt/?be=0&l0=2&l1=0
05-01-2015 5:45 PM
Physical Connectivity OK
DSL Connection
Link Information
Uptime: 0 days, 18:07:04
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Data Transferred (Sent/Received) [MB/GB]: 238.96 / 1.86
Output Power (Up/Down) [dBm]: 11.5 / 13.8
Line Attenuation (Up/Down) [dB]: 6.5 / 9.5
SN Margin (Up/Down) [dB]: 31.0 / 13.7
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 3 / -
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 5
HEC Errors (Up/Down): - / 6
05-01-2015 5:51 PM
What is a little odd is that 0.29 Mbps is a bit slow for your current upstream sync. Is that using a wired or a wireless connection to the router?
05-01-2015 5:56 PM
05-01-2015 5:59 PM
05-01-2015 6:03 PM
05-01-2015 6:27 PM
Other than that you will have to wait for the exchange to be upgraded to 21CN or Fibre to the cabinet to become available. http://www.superfast-openreach.co.uk/where-and-when/ might have some information about that.
05-01-2015 6:33 PM
05-01-2015 6:39 PM
06-01-2015 9:05 AM
06-01-2015 10:06 AM
