Slow upload and ping
- Re: Slow upload and ping
13-06-2012 2:25 PM
Thanks hopefully!
13-06-2012 2:32 PM
We can place an order to uncap the upstream which should uplift the speed from the 440kbit it's on to around about 1Mb? We could also remove interleaving (currently set to auto though I can't see at present if it's being applied or not) in the same order but if your line is prone to drops at all then it'd be worth leaving that on.
The reason I mention is because a ping time of 48ms is not particularly high and certainly shouldn't interfere with your connection.
Please let us know how you'd like to proceed and we'll arrange it for you
13-06-2012 2:44 PM
That was quick, thanks!
I would be happy to go for uncapped upstream and no interleaving asap.
However, I am just sorting out a migration from MAAF to Plusnet. Do I need to get that finished off first? If not then I am happy to go ahead with these changes - the line is solid.
13-06-2012 2:50 PM
13-06-2012 2:54 PM
15-06-2012 8:11 AM
The switch to Plusnet is all done now. Pls can we go ahead with the flip over to uncapped upload, and check/change interleaving?
Thanks!
15-06-2012 10:08 AM
15-06-2012 11:44 AM
15-06-2012 2:34 PM
15-06-2012 5:01 PM
