Slow tonight
- Slow tonight
Re: Slow tonight
14-12-2015 4:07 PM
Re: Slow tonight
15-12-2015 7:34 AM
Re: Slow tonight
15-12-2015 8:42 AM
@CRT,
Is there any insight as to why this 12dB attenuated line synchs as slow as it does? Is it capped?
Re: Slow tonight
15-12-2015 3:40 PM
Re: Slow tonight
15-12-2015 9:08 PM
Re: Slow tonight
16-12-2015 10:39 AM
Looking at the line stats, there is no obvious reason I can see why you aren't connecting higher.
Your line is synced at 16564, which is above the fault threshold rate for your line (15437) so wouldn't be accepted as a fault by our suppliers based on the speed. There are more errors on the line than ideal.
I'm sure this has been asked before, but you are plugged in to the master (test if possible) socket with no extension leads and every other phone point has a filter if it's in use? And is there any noise on the phone line?
Re: Slow tonight
16-12-2015 1:16 PM
Re: Slow tonight
16-12-2015 1:17 PM
Quote The high-speed cable goes from the socket direct to the router.
How long is this cable? Did you manage to check the phone line for noise?
Re: Slow tonight
16-12-2015 1:33 PM
Phone extension wiring, filtered or otherwise, used or not can have a detrimental impact on ADSL performance. If there is more than one extension, there would be no star / branch wiring (it should go from one socket to just the next), there should be only two wires connected - terminals 2&5 - the wires should be twisted pairs.
Extensions run using flat D cable can be very unhelpful!
Re: Slow tonight
16-12-2015 3:28 PM
Otherwise, it's like saying my phone should only have 2 pins in its plug connected, and the cables that connect my phones to their sockets need to be twisted pair.
Re: Slow tonight
16-12-2015 4:12 PM
The cable is 3m as there isn't a socket anywhere near where the master socket comes into the house, and it would be far to dangerous to trail an extension cable.
Nothing is wired from the back of the socket. There is just the broadband cable coming from the filter part and a telephone cable to our phone from the other socket.
This setup worked perfectly well with BE, albeit without the filter plate, but with everything filtered.
Do feel as if the speed is being throttled
Re: Slow tonight
17-12-2015 5:11 PM
Re: Slow tonight
17-12-2015 9:58 PM
Interesting reading
I am still undecided about Fibre at the moment and things I have read in the Fibre section have given me pause for thought, especially that exisitng customers are not getting the same modem router as new customers, especially as I quite like the GUI of my ASUS DSL-N55U.
Will see what the New Year brings.
Re: Slow tonight
19-12-2015 8:26 PM
Re: Slow tonight
20-12-2015 7:51 AM
