Slow speeds
- Slow speeds
Re: Slow speeds
06-01-2011 10:06 PM
Also, do you know if this new faceplate would be compatible with FTTC if I joined the trial? I believe that uses VDSL, not ADSL.
Thanks, Jonny
Re: Slow speeds
06-01-2011 10:16 PM
Re: Slow speeds
06-01-2011 10:20 PM
It has two sets of connections for internal wiring which is what you usually get on a slave socket not a master socket
It appears to have 6 connectors in the socket (where the telephone goes in) mine only has 4
Re: Slow speeds
08-01-2011 12:50 PM
Initially the router was syncing at 28xx kbps, can't remember the exact figure off the top of my head. I've not unplugged anything since but checking this morning my router now has a sync speed of 1149 kbps; here's the full stats:
Data rate(Kbps) 1149Kb 440Kb
Noise Margin 10 23
Output power(dBm) 126 162
Attenuation(dB) 49 27
Any ideas?
Cheers, Jonny
Re: Slow speeds
10-01-2011 10:32 AM
Your line has been banded up to 1148k so that's the maximum sync you'll see. I'll contact our suppliers and see if I can get that raised a bit, so make sure you leave it in the test socket and I'll get back to you when It's done.
Jojo
Re: Slow speeds
10-01-2011 10:58 AM
Quote from: Oldjim Not necessarily wrong just odd
Nothing odd about it, just that its an older faceplate than the one you have oldjim and if you look at the photo of the master socket its got the old BT logo from before the piper logo so I am guessing its from the 80's.
In that situation I would try fitting a NTE2000 faceplate splitter and see if it improves things.
Re: Slow speeds
10-01-2011 11:28 AM
We're still monitoring this while it's in the test socket. We will call you when you can move it from there but for now please leave it where it is, We expect to know more in 24-48 hours.
Jojo
Re: Slow speeds
10-01-2011 1:13 PM
There's been a whole host of information posted on the ticket thread that made no sense to me. Though it has been connected to the test socket since the 6th if that makes any difference to the results.
Cheers, Jonny.
Re: Slow speeds
12-01-2011 10:50 AM
The suggested route forward is to try an SNR reset and to continue to monitor the situation with the test socket still being used. That is fine with me.
Cheers, Jonny.
Re: Slow speeds
12-01-2011 11:16 AM
I'll set about getting the banding lifted now and get back to you once I know more.
Jojo
Re: Slow speeds
12-01-2011 12:14 PM
Jonny
Re: Slow speeds
12-01-2011 1:01 PM
The banding has now been lifted. We will continue to monitor the connection. The ip profile should lift in the next 2 hours.
Jojo
Re: Slow speeds
12-01-2011 1:16 PM
Jonny
Re: Slow speeds
12-01-2011 3:20 PM
Re: Slow speeds
12-01-2011 3:53 PM
I'll run a check now but don't be tempted to reboot at all.
Jojo
