Slow speeds
- Slow speeds
Slow speeds
23-07-2014 3:20 PM
Hi, I seem to only be able to sync at 4500 (tried 3 times at different times of day)and used to be able to get close to 6000 which is killing my download speeds. SNR is 6.0 for upload and download. It there a fault somewhere?
Uptime: 0 days, 7:12:48
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 915 / 4.531
Data Transferred (Sent/Received) [MB/MB]: 4,08 / 13,21
Output Power (Up/Down) [dBm]: 12,7 / 0,0
Line Attenuation (Up/Down) [dB]: 28,8 / 52,0
SN Margin (Up/Down) [dB]: 6,2 / 6,0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 310 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 49 / 374
HEC Errors (Up/Down): 27 / 481
Message 1 of 4
(692 Views)
3 REPLIES 3
Re: Slow speeds
23-07-2014 3:32 PM
Hi grahamholmes,
Your current sync rate is below the Fault Threshold Rate which means that our suppliers would accept this as a fault. Before we go ahead and go through that process, would you be able to connect an alternative microfilter to see if this improves things?
If it doesn't could you connect to your Test Socket as the last thing thing before we progress this as a fault. It'd be handy to get a set of stats again to see if there are any improvements from both tests?
Message 2 of 4
(414 Views)
Re: Slow speeds
24-07-2014 3:09 PM
Hi, I have tried connecting a new microfilter to the test socket and the results are the same, thanks Graham
Uptime: 0 days, 0:03:44
Bandwidth (Up/Down) [kbps/kbps]: 927 / 4.539
Data Transferred (Sent/Received) [kB/kB]: 232,39 / 91,45
Output Power (Up/Down) [dBm]: 12,6 / 0,0
SN Margin (Up/Down) [dB]: 4,8 / 5,9
Error Seconds (Local/Remote): 1 / 0
CRC Errors (Up/Down): 13 / 1
HEC Errors (Up/Down): 4 / 4
Message 3 of 4
(414 Views)
Re: Slow speeds
24-07-2014 3:11 PM
Thanks for doing that.
You can raise a fault online at http://faults.plus.net
Message 4 of 4
(414 Views)
