Slow speeds
absolutepleb
Slow speeds
Hello people. Yesterday BT came out to do some work on my internet exchange because all the phone lines were down in my area. But now, i'm getting extremely slow internet speeds- around 0.7mb download. Normally my download speed is 3.5-4.5mb. Can anyone help?
Edit: also my upload is 0.8mb, apparently the maximum achievable upload speed for my line is 0.83 so its just the download speed which is the problem
Fixes: 62
Re: Slow speeds
please provide the information requested here http://community.plus.net/forum/index.php/topic,96155.0.html and we may be able to help
Acassim
Re: Slow speeds
Hi absolutepleb,
We've just run a few non-intrusive checks on your line and it looks as though the fault has ended up lowering your speed profile. I've now upped this back to the rate you had before so you should see the speed return if you can give it a check?
The testing did show a few line errors which aren't a major concern if you're only seeing problems with speed since the fault fix. May be best to keep your eye on it and let us know if you have any additional issue moving forward.
absolutepleb
Re: Slow speeds
Hi guys, thanks for the fast replies, it's back to the normal download speed, thanks very much for the assistance. The line errors you are talking about is when someone uses the land line phone and the internet cuts out for around two minutes each time. It's been like that for a long time. It's a problem i can live with, but any suggestions would be welcome. Thanks for your time!
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Slow speeds
Hi absolutepleb,
Thanks for letting us know that the speeds are back to normal. Have you tried to swapping the microfilter that you've got for an alternative to see if that fixes the issue with your landline cutting out the broadband?
Chris Pettitt
Cloud Environments Engineer
absolutepleb
Re: Slow speeds
Thanks Chris, I will try this when I can get hold of one and report back.
jim:quote
absolutepleb
Re: Slow speeds
Would someone mind checking my IP profile again? It seems to have gone back to super slow speed.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Slow speeds
I can see your speeds dropped quite significantly, to around 700K this morning.
Can you please visit http://faults.plus.net and complete the Fault Checker so that our Faults Team can get this looked into for you?
Chris Pettitt
