Slow speeds
- Slow speeds
- « Previous
- Next »
Re: Slow speeds
29-10-2014 10:49 AM
Re: Slow speeds
29-10-2014 12:34 PM
Thank you guys.
Den
Re: Slow speeds
29-10-2014 2:23 PM
Now have firmware 10.2.2.B
Also new router stats.
DSL Connection
Link Information
Uptime: 0 days, 0:11:56
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 5.024
Data Transferred (Sent/Received) [MB/MB]: 3,09 / 16,68
Output Power (Up/Down) [dBm]: 12,3 / 19,9
Line Attenuation (Up/Down) [dB]: 27,5 / 49,0
SN Margin (Up/Down) [dB]: 20,0 / 6,0
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 0 / -
FEC Errors (Up/Down): 0 / 7.304
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): - / 0
Thanks again.
Den.
Re: Slow speeds
29-10-2014 8:49 PM
Certainly don't do anything anytime between an hour before sunset and an hour after sunrise, but in daylight hours (around middayish is often best) - IF the SNRM is steady and better than say 6.4dB it would be worth a resync to see if you can get the speed to 5120 or a touch higher. There's not much point in it being much higher on 20CN, it would have to go to 5696 to get a 5Mbps profile and I would say the SNRM would drop too low at night that your line may get unstable.
If you see this post this evening, post the current stats so we get an idea of what you line is like after dark.
Re: Slow speeds
30-10-2014 9:09 AM
DSL Connection
Link Information
Uptime: 0 days, 15:38:03
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4.992
Data Transferred (Sent/Received) [MB/GB]: 199,22 / 2,08
SN Margin (Up/Down) [dB]: 20,0 / 5,9
Error Seconds (Local/Remote): 45 / -
FEC Errors (Up/Down): 7 / 462.818
CRC Errors (Up/Down): 4 / 88
HEC Errors (Up/Down): - / 1.089
Re: Slow speeds
30-10-2014 9:18 AM
Re: Slow speeds
30-10-2014 9:54 AM
Re: Slow speeds
30-10-2014 12:45 PM
DSL Connection
Link Information
Uptime: 0 days, 19:10:30
Data Transferred (Sent/Received) [MB/GB]: 236,15 / 2,33
Error Seconds (Local/Remote): 49 / -
FEC Errors (Up/Down): 17 / 635.441
CRC Errors (Up/Down): 5 / 93
HEC Errors (Up/Down): - / 1.132
Thanks.
Den.
Re: Slow speeds
30-10-2014 1:51 PM
All in all things look promising.
Re: Slow speeds
30-10-2014 7:40 PM
Sorry still learning
Physical Connectivity OK
DSL Connection
Link Information
Uptime: 1 day, 2:02:56
Data Transferred (Sent/Received) [MB/GB]: 324,41 / 2,87
SN Margin (Up/Down) [dB]: 20,0 / 5,6
Error Seconds (Local/Remote): 55 / -
FEC Errors (Up/Down): 35 / 2.786.640
CRC Errors (Up/Down): 7 / 102
Den.
Re: Slow speeds
30-10-2014 8:22 PM
When the modem syncs with the exchange they negotiate the fastest sync speed possible until the noise margin is at the target (6dB in your case). If you were to resync now the sync speed would be slower with the margin back at 6dB, but during the day tomorrow you would see it rise well above 6. That's why we advise resyncing during the day when background interference is lowest as that gives the best sync speed.
Re: Slow speeds
31-10-2014 7:22 AM
Thanks.
Den.
Re: Slow speeds
31-10-2014 7:38 AM
- « Previous
- Next »
