Slow speeds
- Re: Slow speeds
Slow speeds
26-07-2012 7:51 PM
Hello all,
Around 8-9 I was experiencing allot of disconnects. Thanks to Anotherone I managed to track down the problem to a phone line fault. I have ringed up BT and they have said the problem has been resolved :).
However all the disconnects have caused my speeds to slow down... and quite sharply to. In hope for the speeds to return back to normal I have waited around 4-5 days,no luck :(. I'm not sure if I have been capped or... but I would really appreciate some help in getting the speed back up to what they use to. Last time I had my speeds capped ,JoJo kindly uncapped it and hadn't had a problem for around 8-9 months.
Speeds:
downstream upstream
Attainable Rate (Kbps) 21292 888
current rate (Kbps) 6652 440 (dropped from around 19000 downstream and from 888 upstream)
Speeds:
downstream upstream
Message 1 of 9
(1,525 Views)
8 REPLIES 8
Re: Slow speeds
26-07-2012 8:01 PM
I think that you will need to ask for the line to be retrained and for the upstream to be uncapped
Message 2 of 9
(679 Views)
Re: Slow speeds
27-07-2012 9:22 AM
Hello,
This must sound awfully stupid but who do I actually ask from my line to be retrained? BT or PN
Also would a SNR reset increase my speeds as my noise margins are a bit high at the moment :
downstream upstream
SNR Margin (0.1 dB): 163 306
downstream upstream
Message 3 of 9
(679 Views)
Re: Slow speeds
27-07-2012 9:32 AM
Plusnet - either by it being picked up here or via a ticket
Message 4 of 9
(679 Views)
Re: Slow speeds
27-07-2012 10:06 AM
Your IP profile has been banded, hence you having the slow speeds. You connection is now stable so I have placed a SNR reset on your line, this usually takes around 4 hours to take place, but can sometimes need leaving over night.
This should get you back to your usual speeds.
Let me know how you go.
Chris
Chris
Message 5 of 9
(679 Views)
Re: Slow speeds
27-07-2012 4:36 PM
Hi Chris,
Its certainly past the 4 hours and nothing really has changed, i guess ill just wait overnight
I'll let you know if anything has changed in the morning.
Message 6 of 9
(679 Views)
Re: Slow speeds
27-07-2012 5:28 PM
The SNR reset has been placed, so check in the morning. and hopefully you'll see the increase.
Message 7 of 9
(679 Views)
Re: Slow speeds
28-07-2012 10:12 AM
Hi chris,
Well its morning and i can safety say my sync speeds have increased to:
Downstream Upstream
Rate (Kbps): 17515 888
Downstream still not around the 19000 Kbps mark but I'm not brothered :). However despite the increase in downstream sync I only get a solid 8 Mbps download speed (but I think it will pick up by itself).
After looking at my router stats I noticed that I had ALOT of HEC errors, 4294967286 to be precise.I have no idea what HEC errors even are but I'v noticed at times I get no HEC errors and then suddenly get this number. Is this normal?
Downstream Upstream
Message 8 of 9
(679 Views)
Re: Slow speeds
30-07-2012 4:00 PM
Good to see that your speeds have picked up.This is a definition of HEC errors: Count of HEC Errors. HEC is a type of CRC error check which has been performed on the header of an ATM cell, but 1 bit errors can be corrected. This count is usually where HECs have been uncorrected and have been discarded.
If these errors are too high within a short period of time it will slow throughput and could even lead to connection instability.
This could be the reason your speeds haven't reached back to where they should be. You've also had a few disconnections yesterday.
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13436601472378.png" />
Have you powered your router off at all? If possible I would suggest connecting into your <a href="http://www.plus.net/support/broadband/master-socket-guide.shtml#whatsTest">test socket</a> and see if your line is any more stable there. Have you been rebooting your router at all?
If not I'd suggest raising a fault at http://faults.plus.net.
Message 9 of 9
(679 Views)
