Slow speeds
jasper
Slow speeds
Wondering what has happened to my broadband speed?
It was up around 50mb, Now at just over 20mb.
Current Contract
Unlimited Fibre Extra inc. Line rental
17 REPLIES 17
Legend
Fixes: 255
Re: Slow speeds
@jasper You have a network problem is what has happened to your speed. 😉 I can't tell from those two screen shots where the problem may lie, but I  suggest you report the issue, either by the automated tool found in the 'Help & Support' pages, or at https://faults.plus.net
Fixes: 1,600
Re: Slow speeds
If you can private message me your account username, I'll be happy to take a look at this for you
adam945
Fixes: 113
Re: Slow speeds
Thanks a lot for providing us with the account username @Jasper, and I too am really sorry to hear that you're having speed issues with your service. Tests on the line have uncovered a potential fault, so I've just raised a ticket for you to do some troubleshooting and to respond to in order to arrange an engineer visit if needs be.
 Adam
 Plusnet Help Team - Leeds
jasper
Re: Slow speeds
Thank you Adam, much appreciated.
jasper
Re: Slow speeds
Hello Adam,
Where can i find the requested information required?
Legend
Fixes: 255
Re: Slow speeds
@jasper What information have you been asked for/what have you been asked to do?
jasper
Re: Slow speeds
The post by Adam said a ticket had been raised for me to do some trouble shooting and to respond.
Legend
Fixes: 255
Re: Slow speeds
Ah - got you. To get access to the ticket, log into your account, and there should be a banner saying something to the effect that you have an open ticket, across the landing page.
jasper
Re: Slow speeds
Hello John,
Nope... no banner here: https://www.plus.net/member-centre/home
Legend
Fixes: 255
Re: Slow speeds
I feared you might come back and say that - the ticket system appears to be in a state of total disarray. Try this: while still logged into your account, open Plusnet in a a NEW tab, and see if you can find a recent ticket in there - it may be closed though, as the system appears to not recognise when tickets should be left open. Let me know how you get on.
jasper
Re: Slow speeds
Hello John,
i have removed the faceplate, and plugged the micro filter and "phone wire" directly into the master socket to router, restarted the router, and wired in a laptop directly into one of the router ports. Still the speed is 24.98 DL,13.94 UL. This has fluctuated some times back up to 44 ish, but not consistently, without me doing anything.
Legend
Fixes: 255
Re: Slow speeds
OK, I don't know exactly what is on the troubleshooting tips - never had to go that way myself as I have enough experience to be able to bypass 'official' instructions, but it sounds to me like there is a fault on the BT/OR network. Hopefully, @adam945 or one of the other Help Team members will pick this up and raise it with BT/OR direct.
jasper
Re: Slow speeds
Thank you John,
I had noticed that, when leaving the router on, the network uptime is less that the system uptime. So the network is dropping somewhere.
Legend
Fixes: 255
Re: Slow speeds
Another indication of a BT network issue. As a point of note, you should never turn the modem/router off, unless specifically requested to - this can lead to the Dynamic Line Management system thinking there is a problem, and therefore reducing the speed/banding the line.
