Slow speeds today.
- Re: Slow speeds today.
Slow speeds today.
19-04-2012 10:09 PM
20-04-2012 1:00 PM
My sync has risen from 10.8 to 12.4 but the PN profile is still stuck on 10.3.
Estimated line speed:7Mb (Accurate to within +/- 1Mbit) - Checked on 2012-01-22 15:06:31Current line speed: 10.3 Mb
My speed has been stuck at 9.7 for ages, it went up to 10.3 for a day then dropped again.
Thanks for reading.
20-04-2012 1:26 PM
I suspect the slowdown was caused by being on a busy gateway yesterday following the afternoon's outage rather than any sort of line issue. If you didn't lose connection that will almost certainly be the case, as the working gateways (those not connected via the Colindale node) will be where all the customers who'd dropped would reconnect to, hence the slowdowns.
If that's not the case please let us know, but things should improve as we're in the process of sorting out the network balance now.
20-04-2012 1:37 PM
If it's one of these:
21CN:
pcl-ag06 WBC.Colindale1
pcl-ag07 WBC.Colindale1
ptn-ag2 WBC.Colindale1
ptw-ag03 WBC.Faraday1
ptw-ag01 WBC.Faraday1
ptw-ag02 WBC.Faraday1
20CN
pcl-ag01 IPSC.Faraday2
pcl-ag02 IPSC.Faraday2
pcl-ag03 IPSC.Faraday2
pcl-ag04 IPSC.Faraday2
pcl-ag05 IPSC.Faraday2
pcl-ag07 IPSC.Faraday2
pcl-ag08 IPSC.Faraday2
ptn-ag2 IPSC.Faraday1
ptw-ag01 IPSC.Faraday1
ptw-ag03 IPSC.Faraday1
It'd probably be worth dropping the connection then reconnecting to try and get onto a different one that's not listed above as they're a lot less congested.
20-04-2012 1:43 PM
Edit - typo corrected
20-04-2012 1:51 PM
Should that be why aren't both 21CN and 20CN affected when they are on the same gateway? ;
20-04-2012 2:42 PM
Matt, the speed is back to normal now, I didn't loose connection either so thanks for the heads up on the outages. I am on one of those gateways so I will do a reset tomorrow morning.
Also is there any chance of upping my PN profile ?
Thanks in advance,
Jim.
20-04-2012 3:08 PM
20-04-2012 3:56 PM
20-04-2012 4:32 PM
30-04-2012 8:42 PM
30-04-2012 9:55 PM
30-04-2012 10:00 PM
30-04-2012 10:20 PM
01-05-2012 1:09 PM
Did it get better later? In general was it ok apart from last night?
Jojo
