Slow speeds since yesterday
martyn90125
Hello, yesterday evening my router restarted and since then my DL/UP speeds have been pretty bad, for the last 3 years I've had a steady 80down/20up but now it's 33down/1up.
Does anyone know why this is happening?
9 REPLIES 9
Fixes: 334
Re: Slow speeds since yesterday
@martyn90125 If you can read through and answer the text below (ignoring the bits you have already done), we may be able to offer some help/suggestions.
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub would be a good starting point.
For the Hub One -
For the Hub Two -
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
martyn90125
Thanks for the reply, strangely enough i just checked my phone line and it just doesn't seem to be working at all, no dial tone, nothing, i unplugged and plugged it back in and still nothing.
Fixes: 334
Report a phone issue first, then.
martyn90125
Alright thanks, will do that.
martyn90125
Just an update, i logged a phone fault and they ran a test and found a fault so hopefully it's fixed in 1-4 days.
martyn90125
Just thought I would update and say the issue has been fixed, back to my normal 80down/20up.
adamwalker
Fixes: 223
Hi there Martyn, cheers for your patience with this, Openreach have cleared the line fault back to us this afternoon, could you check and confirm if that's made any improvement to the connection speeds for you? - Adam
 Adam Walker
RealAleMadrid
Fixes: 66
@adamwalker Did you miss @martyn90125's post a minute before yours, full speed has been restored😀
adamwalker
Fixes: 223
Hey, I did, there can be a delay between replies being sent and pulling through to our social media client that we use to respond with. That's great to see Smiley
 Adam Walker
