Slow speeds on upgaraded Line
- Slow speeds on upgaraded Line
09-01-2014 5:28 PM
Re: Slow speeds on upgaraded Line
09-01-2014 5:49 PM
Have PN moved you over to ADSL2+ yet?
Can you post your router stats?
You're understanding is correct about the IP Profile restricting your speed - just need to find out why the IP Profile is lower than expected.
09-01-2014 6:17 PM
are this the stats your need
Link Information
Uptime: 0 days, 1:18:38
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 445 / 22.007
Data Transferred (Sent/Received) [MB/MB]: 18,93 / 361,62
Output Power (Up/Down) [dBm]: 9,1 / 0,0
Line Attenuation (Up/Down) [dB]: 8,3 / 14,0
SN Margin (Up/Down) [dB]: 32,7 / 3,1
Loss of Link (Remote): -
Error Seconds (Local/Remote): 6 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 6
HEC Errors (Up/Down): 0 / 16
09-01-2014 7:40 PM
It's also worth getting your upload speed uncapped (is no extra cost for this and it will benefit you).
09-01-2014 7:50 PM
Might be worth trying a disconnect/reconnect via the router GUI, this can sometimes wake up the profile.
10-01-2014 4:48 PM
10-01-2014 4:52 PM
Is the BT IP profile still stuck @ 7.15 after the re-synch?
10-01-2014 6:55 PM
13-01-2014 11:08 AM
14-01-2014 2:04 PM
BT wholesale results as of 2 minutes ago
Download speedachieved during the test was - 7.76 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 7.15 Mbps
14-01-2014 2:51 PM
