Slow speeds for a week
andyp
Hi - am on Plusnet Unlimited.
Have been experiencing very slow speeds for the past week or so. BT Wholesale Test results:
Download speedachieved during the test was - 8.54 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 8.58 Mbps
Upload speed achieved during the test was - 1.01Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Anyone got any ideas? Thanks!
andyp
Re: Slow speeds for a week
Have just run another speed test - see below:
<a href="http://www.speedtest.net/my-result/3398099663"><img src="http://www.speedtest.net/result/3398099663.png" /></a>
Before last week, we were getting speeds in excess of 12Mb/s.
Nothing has changed - equipment is still the same etc.
Can anyone shed some light please..? Thanks
andyp
OK - another test before work:
<a href="http://www.speedtest.net/my-result/3398807301"><img src="http://www.speedtest.net/result/3398807301.png" /></a>
Again, not great...
Am I being throttled..? Can anyone help please..?
Your IP Profile has been reduced and possibly interleaving turned on to stabilise your line - have you had problems with disconnections recently? Can you post your router stats?
Plusnet Staff
Plusnet Staff
Fixes: 5
Really sorry that you're seeing lower than expected speeds. Here's a log of your connection:
<img src="http://community.plus.net/visualradius/generated/image13959143851422.png"/>
In my opinion, it's pretty stable, but something has caused your line to become <a href="http://community.plus.net/library/broadband/broadband-faults-guide-banding-guide/">banded</a>.
I've completed an SNR Reset on your line for the banding to be removed. Please let us know if this hasn't resolve the issue for you.
Chris Pettitt
Cloud Environments Engineer
andyp
Thanks Andy and Chris
Speed is now worse:
<a href="http://www.speedtest.net/my-result/3400091749"><img src="http://www.speedtest.net/result/3400091749.png" /></a>
I've not had stability issues prior to the slowdown...
andyp
Far better now:
<a href="http://www.speedtest.net/my-result/3400278699"><img src="http://www.speedtest.net/result/3400278699.png" /></a>
andyp
And right back down again:
<a href="http://www.speedtest.net/my-result/3400308790"><img src="http://www.speedtest.net/result/3400308790.png" /></a>
andyp
An early morning speed test:
<a href="http://www.speedtest.net/my-result/3401108514"><img src="http://www.speedtest.net/result/3401108514.png" /></a>
Plusnet Staff
Plusnet Staff
Fixes: 5
The Speed Tests you running, are they over Wireless or Ethernet?
Chris Pettitt
andyp
Results for ethernet:
Download speedachieved during the test was - 5.14 Mbps
IP Profile for your line is - 15.07 Mbps
andyp
Getting worse:
Download speedachieved during the test was - 3.7 Mbps
IP Profile for your line is - 14.32 Mbps
Plusnet Staff
Plusnet Staff
Fixes: 5
Hi andyp,
I would advise for you to raise a fault at http://faults.plus.net as your line is erroring for some reason which is causing your connection to behave so abnormally.
Errors occur when conditions on your line become adverse and your Signal To Noise Ratio (SNR) is unable to sustain them. Our Faults Team will be able to get this looked into in further detail.
Chris Pettitt
