Slow speeds, dropouts and crackling phone line :(
- Slow speeds, dropouts and crackling phone line :(
29-05-2016 10:50 PM
Hiya, I've been with plusnet for about 2 and a half years now, and through that time our ADSL connection has been rock solid at 6.5mbps down and 1mpbs up with no disconnects. The last 1-2 weeks have been rough though, with occasional disconnects and slower speeds.
Our profile is now set to 4mpbs and we can barely get 0.3mpbs up tonight, its struggled to get any DSL connection at all and it took about 5 tries to get a dial tone on our phone.
Can anyone help?
Re: Slow speeds, dropouts and crackling phone line :(
30-05-2016 8:46 AM
I would suggest you log a phone fault with your phone provider as the noise on the line will affect your ADSL connection. When the voice issue is fixed that should hopefully solve the ADSL issue.
DO NOT mention the bad ADSL connection, get the phone fault fixed first.
Assuming Plusnet are your phone provider, then the phone troubleshooting guide is at https://www.plus.net/help/phone/phone-line-troubleshooting/
30-05-2016 8:48 AM - edited 30-05-2016 8:51 AM
Good Morning,
I've ran a test on your phone line(the low speed is most likely a result of the phone issues) and a fault is showing, it is external so no appointment is required, the estimated response time is Thursday but these kind of issues can be fixed earlier than expected in some cases.
I'll raise a ticket to our faults team to monitor this for you
30-05-2016 10:51 AM
I made a quick video before I saw this of how bad it is. This is with the phone plugged directly into the master socket.
https://goo.gl/photos/Ggx4ktpoMngPPTqMA
Strangely the next call I did had static but nowhere near as bad I could actually hear the response
I know maybe 1-2 months ago they swapped our old rusty cabinet with a new shiney one ready for fibre so maybe they missed something then.
30-05-2016 10:55 AM
01-06-2016 11:18 PM - edited 01-06-2016 11:19 PM
I'm not sure if the fault has been looked into yet, but the phone line finally became clear after 2-3 days of being nothing but static.
The upload speed has also gone back close to 1mpbs, but our download speed is stuck at about 2.73mpbs after a modem reboot Really hoping it gets back to 6-6.5mbps
02-06-2016 9:22 AM
02-06-2016 9:26 AM
Your line is now syncing at 5656, giving a profile of 4900. The SNR is a little high probably due to the phone fault, so I'm going to reset that now and you should get a little more out of your line shortly.
Chris Parr Plusnet Staff |
02-06-2016 9:53 AM
Thanks for looking into this Chris, appreciated! It looks like I'm back up to downloading around 600kbs Thats a big improvement over the 340kbs max I had last night.
Is it likely the line may stable out a bit more over the next few days to its old speed? It used to be around 650kbs. I'm not sure if the profiles adjust periodically.
Thanks,
Ste
02-06-2016 10:23 AM
02-06-2016 11:08 AM
Thanks again for your help And Darkfire of course.
