Slow speeds, decreasing router sync speed
- Re: Slow speeds, decreasing router sync speed
18-06-2009 1:15 PM
I have been having problems with d/l speed for 2 weeks now, and resorted last weekend to plugging the router into the master socket, with no other equipment connected.
I was amazed when the router sync speed went up to 3700 KBPS and BT BRAS profile up to 3000, and my download speed on the morning of the 3rd day was up to 2500 KBPS.
However, by the evening of the 3rd day, my download speed had dropped back to 135 KBPS, even though the BT profile was still 3000, and the router sync speed had fallen back to 1250 KBPS. Yesterday, the router sync speed had dropped still further, so I resorted to re-booting the rooter, which, although it improved my download speed to about 300 KBPS, the router sync speed has dropped to about 500 KBPS.
Has anybody got any suggestions why this thing is fluctuating so much? I have an open ticket with the 1st line PN support team, but they still haven't pinned it down to anything in particular. I am using a replacement (new) router plugged straight into the master socket, and it is bugging me that this problem is not going away!!
Any help would be appreciated.
Cheers
Stuart
18-06-2009 1:19 PM
18-06-2009 8:26 PM
I have been plugged into the test socket for the last few days, which got speeds up to 2.5Mb for about 8 hours on the third day, but it then dropped right back to 138Kb again the same evening while still in the test socket.
Cheers
Stuart
18-06-2009 8:34 PM
I suspect you are just going to have to wait for the fault team to either track it down or get BT out but if you can post the stats from your router (attenuation, noise margin and speeds) we might have a better idea as to what is going on.
While we are at it which router do you have
18-06-2009 9:13 PM
It is a Thomson Gateway supplied by PN recently to eliminate my existing router as a possible cause.
Here are the stats below:-
Uptime: 0 days, 9:47:17
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 480
Output Power (Up/Down) [dBm]: 12.0 / 15.0
Line Attenuation (Up/Down) [dB]: 31.0 / 55.0
SN Margin (Up/Down) [dB]: 18.0 / 14.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 21 / 0
Loss of Signal (Local/Remote): 28 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 62 / 0
FEC Errors (Up/Down): 53 / 7,564,875
CRC Errors (Up/Down): 53 / 1,111
HEC Errors (Up/Down): 33 / 469
Cheers
Stuart
18-06-2009 9:23 PM
20-06-2009 5:57 PM
I have donwnloaded router stats, and can get the basic graphs for noise and download speed working ok, but the Telnet router screen is blank, despite changing the Experimanetal Tab to Broadcom.
I think that if I could get this open, I would be able to reduce my signal to noise margin which would hopefully increase the speed.
As a reminder, my router is a Thomson TG585 v7.
Any suggestions on how to set the Telnet screen up to get it working?
Cheers
Stuart
20-06-2009 6:36 PM
Quote The default login is 'Administrator' with no password. It seems that RouterStats won't send a blank password, so I changed the password on the ST585 to a non-blank value, and it logs in without a problem.
21-06-2009 2:44 AM
21-06-2009 10:24 AM
Also, I powered down the router yesterday in order to disconnect the bell wire in the master socket, and when I re-booted I was up to 2.5Mb download speed, with router syncing at 3.0Mb and SNR of 9.5dB.
This morning, router sync speed has dropped to 1.4Mb and SNR has dropped to 3.0dB?
Any ideas why this might be?
Thanks for your help so far.
Cheers
Stuart
21-06-2009 11:58 AM
If I can get Telnet working then hopefully I can tweak the SNR ratio to a lower figure and see if d/l speeds increase again.
It is getting better though
21-06-2009 11:59 AM
