Slow speeds - Noisy Line (Still not resolved!!)
- Slow speeds - Noisy Line (Still not resolved!!)
- « Previous
- 1
- 2
- Next »
Re: Slow speeds - Noisy Line
18-06-2010 5:15 PM
i had a simliar problem i had to get an engineer out from BT to fix my line.
18-06-2010 5:22 PM
19-06-2010 11:00 AM
Think the noise on the line is intermittent. but can't stream any videos.
My 3 Dongle did better than this
19-06-2010 11:09 AM
DSL Connection
Link Information
Uptime: 0 days, 0:46:34
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,376
Output Power (Up/Down) [dBm]: 11.5 / 17.0
Line Attenuation (Up/Down) [dB]: 31.5 / 55.0
SN Margin (Up/Down) [dB]: 20.0 / 19.0
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Framing (Local/Remote): 146 / 0
Loss of Signal (Local/Remote): 649 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 584 / 0
FEC Errors (Up/Down): 0 / 12
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
20-06-2010 10:49 AM
DSL Connection
Link Information
Uptime: 0 days, 12:01:33
Bandwidth (Up/Down) [kbps/kbps]: 448 / 160
Output Power (Up/Down) [dBm]: 11.5 / 11.0
SN Margin (Up/Down) [dB]: 19.0 / 27.5
Loss of Framing (Local/Remote): 150 / 0
Loss of Signal (Local/Remote): 701 / 0
Error Seconds (Local/Remote): 653 / 0
FEC Errors (Up/Down): 2 / 847
CRC Errors (Up/Down): 2 / 964
HEC Errors (Up/Down): 1 / 372
Not sure what all this means. Can some one explain it to me please.
Thanks, Dan
20-06-2010 11:05 AM
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
113 Kbps
0 Kbps 250 Kbps
Max Achievable Speed
Download speedachieved during the test was - 113 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :160 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
20-06-2010 11:23 PM
Download Speed
113 Kbps
0 Kbps 250 Kbps
Can somebody please help, I am running out of ideas and patience.
21-06-2010 1:26 PM
Glad you got the reference even if that wasn't your reasoning
I've just checked the phone fault we've got raised for you and it's saying that an engineer visit has been booked for tomorrow afternoon - I hope this isn't a problem, please let me know if so and I'll get it rearranged for you. I hope that when the phone fault is fixed your broadband speeds will pick up - usually they do in these cases.
21-06-2010 7:57 PM
thanks for your help on this.
The other half is going to be in tomorrow afternoon for the engineer so leave the appointment booked.
Hopefully they can sort their line out and speeds pick up.
Thanks again
21-06-2010 8:11 PM
FAQ
Download Speed
458 Kbps
0 Kbps 500 Kbps
Download speedachieved during the test was - 458 Kbps
For your connection, the acceptable range of speeds is 50-500 Kbps.
Your DSL Connection Rate :896 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 500 Kbps
Much better!
What is going on? lol Completely different from one day to the next
21-06-2010 11:32 PM
Download Speed
635 Kbps
0 Kbps 2000 Kbps
Download speedachieved during the test was - 635 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Your DSL Connection Rate :1920 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1500 Kbps
Things are looking good
Still not sure what has changed
22-06-2010 2:46 PM
22-06-2010 6:26 PM
Back down again now
FAQ
Download Speed
309 Kbps
0 Kbps 500 Kbps
Download speedachieved during the test was - 309 Kbps
Your DSL Connection Rate :512 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 350 Kbps
24-06-2010 11:22 PM
Did the BT Speedtest again last night and my IP Profile is coming back up
Tonight I ran it again and it asked me to continue with Test 2, but to log on as bt_user_test@plusdsl.net.
These are the results
Results Image not loaded
This Test comprises of Best Effort Test: -provides background information.
Download Speed
1166 Kbps
0 Kbps 2000 Kbps
Download speedachieved during the test was - 1166 Kbps
Your DSL Connection Rate :1664 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1250 Kbps
Your service was found to be performing poorly. Please raise a fault with your service provider, stating that the BT Performance Tester tool indicates poor service throughput performance after the first test.
Please let me know what you think.
Your help is much appreciated.
Bueller
27-06-2010 7:29 PM
Download Speed
222 Kbps
0 Kbps 250 Kbps
Download speedachieved during the test was - 222 Kbps
Your DSL Connection Rate :1536 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 250 Kbps
What can I do?????????
Not very happy with the level of service at the moment.
I know it may not be Plusnet, probably BT, but my 3 dongle was getting better speeds than this
- « Previous
- 1
- 2
- Next »
