Slow speed
BLINDPEW
Slow speed
I'm just wondering why my speed is set at 4500 and has been like this for over 4 days. Has you can see below  from my router stats, I should be on at least 8000. Has anyone got any ideas. Can I just confirm on speedtester for the last few days I'm averageing 4100 download speed.
DSL Connection
Link Information
Uptime: 4 days, 1:46:28
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 440 / 8,328
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 20.0 / 43.5
SN Margin (Up/Down) [dB]: 25.5 / 8.5
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): 0
Fixes: 61
Re: Slow speed
is that from the BT speedtest or Plusnet.
If from Plusnet can you check with the BT speedtest
BLINDPEW
Re: Slow speed
I usually use the plusnet speedtester but I do use the BT one aswell heres the latest one, and just to confirm this has been the average speed results for the last few days.
Download speedachieved during the test was - 4158 Kbps
For your connection, the acceptable range of speedsis 1000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :8328 Kbps(DOWN-STREAM), 440 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 15.38:31.79:52.83 (SBE:NBETongueBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes
Fixes: 61
Re: Slow speed
and what does this say for your current line speed https://portal.plus.net/my.html?action=data_transfer_speed
Re: Slow speed
It will have said 4000kbps but now says 6500kbps after I fixed it Wink
BLINDPEW
Re: Slow speed
Current line speed shows has 4500.
Fixes: 61
Re: Slow speed
There is the answer - and Ben has fixed it.  Grin
However I am not sure why the IP profile isn't higher unless you had a slightly lower sync in the last few days
BLINDPEW
Re: Slow speed
Thanks Ben for that quick responce. I'm now getting download speeds of 5990, but can I just add that I am on ADSL2+ and last week I was averaging download speeds of 7000+ and with the router stats that i'm showing I thought it would still be getting around this figure.
BLINDPEW
Re: Slow speed
Sorry replies must have crossed. No its been constant at that, the only reason it shows 4 days is I replaced my router for a new one from plusnet, but it was showing same stats on old thompson 580WL,
Re: Slow speed
Based on your synchronisation speed you'll get a 7150 profile if the line remains stable.
BLINDPEW
Re: Slow speed
Thanks for your help Ben.
