Slow speed since moving to BBYW2
kim432
I moved from BB+ to BBYW2 last week, however I've noticed that my download speeds (from web sites not P2P) have since decreased from an average of 850kbs to 200kbs since switching over. When I visited this page: https://portal.plus.net/my.html?action=data_transfer_speed I noticed it says "Your current broadband speed is 2000 Kbps". Has my line been reduced to 2mbs since the switch over and if so why is that when I was having no trouble with the higher speeds previously? The reason I switched over the in the first place was to achieve higher P2P speeds but seeing as I'm now getting significantly slower speeds I'm kinda regretting it!
Hope this makes some sense!
Fixes: 5
Re: Slow speed since moving to BBYW2
What does the [url=http://portal.plus.net/support/broadband/troubleshooting/bt_speed_tester.shtml]BT Speedtest/url] say your IP Profile is?
Phil
kim432
I'm getting "Authorisation failed Incorrect Telephone Number - Please try again" when I try to use that link.
Plusnet Staff
Plusnet Staff
Fixes: 159
Hmm looks like someone has altered the profile our end before I had chance to check. Can you reboot your modem/router and see if the speeds have improved please?
 Chris Parr
 Plusnet Staff
kim432
Hi, Sorry for the delayed response.
After posting the first message someone seemed to alter the speed so all is good now. Thank you.  Smiley
