Slow speed in evenings and night time.
Iloveplusnot
Is it just me? The connection seem to me quite good daytime but gets extremely slow once the Support lines close Smiley
I thought it was bad luck or heatwave causes some issues but it just gest worse.
Reseting the hub helps. Sometimes. For some time. Next day and the same problem. Download speed 1 Mbps.
7 REPLIES 7
Fixes: 334
Re: Slow speed in evenings and night time.
What connection are you on ADS/FTTC?
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
Iloveplusnot
Estimated download speed: 38 - 40Mbps
Fixes: 334
FTTC - Have you followed my link?
Iloveplusnot
  • Service available Mon-Sun: 8am to 7.30pm
    That makes it tricky when I get home at 8pm
Fixes: 334
If you submit a report outside those hours, it will be queued and and picked up during them.
Fixes: 124
Being a text service, I doubt it is necessary to be at home to use it.
Alternative to the text service you could use https://faults.plus.net
HTH
willcutforth
Fixes: 113
@Iloveplusnot It's found an external fault. It is an Earth Contact on the line and should be fixed within the next few days.
 Will Cutforth
