Slow, slow, very very slow
- Slow, slow, very very slow
Re: Slow, slow, very very slow
26-10-2011 10:07 AM
To be is to do - Kant
do be do be do - Sinatra
26-10-2011 11:41 AM
I've had a look under the BT wall plate and deduced that disconnection of the extension bell is beyond my skill level. The bell itself is concealed inside a box about 9" by 6" mounted high up on the wall in the next room. No idea what is inside it.
I've switched back to the original filter and rerun the BT speedtest, which gave me the same poor result as earlier this morning. I've also just been next door, who have their phone line connected to the same telegraph pole & have run a broadbandspeedcker there (couldn't run BT speedtest as Java was not installed & I didn't want to change their system). Their download speed came up as 664 kbps and upload speed is 277 kbps, which is even worse than mine. This could indicate that we have a common problem.
I don't really know what to do next, but am getting more & more fed up ....
Any help would be much appreciated.
26-10-2011 12:32 PM
Does the main socket have a removable lower half with a test socket inside? If so when it is open, does the bell still ring?
26-10-2011 3:23 PM
28-10-2011 2:39 PM
I've got stuff to do on my computer so I can't keep it connected to the main router in my hallway indefinitely. I'm moving it back to my study now but will be happy to do more tests directly connected to the router when requested. I'm hoping that I'll get a response soon ...
28-10-2011 4:08 PM
When you say you're moving it back from the hall, do you mean there is an extension from the phone socket to the router or an extension from the router to the computer?
Jojo
28-10-2011 11:04 PM
Neither. As I have said before in this thread I have got my router attached to my main phone point (in my hall) via a cable about 2 metres long. I have been running lots of tests with my laptop attached to the router via an ethernet cable. This means that I have to perch or squat on the floor & it's very awkward. Also my printer is out of reach from here.
I got fed up waiting for a response to my fault so I moved my laptop temporarily back in to my study so that I could do some offline work more comfortably. I've left my router in the hall & switched on.
Now I'm back in the hallway in order to reply to this.
31-10-2011 11:12 AM
That 2m long extension won't help matters. you need to be directly in the test socket or we won't be able to pinpoint the problem. I appreciate it's a pain but if you could plug just your filter into the test socket then into your router it will really help. can you let me know when you've done that?
Jojo
01-11-2011 9:46 PM
Sorry, you have misunderstood what I said re the connection of my router. It isn't connected via an extension. It is connected to a filter via a grey internet cable about 2m long and the filter is connected directly to the main telephone point. I don't have a test socket.
I have since received a response to my fault & have received today a new wireless router. I have followed the installation instructions and have established internet connection through the new router. I have run the BT speedtest twice this evening (about 2 hours apart) and got download speed of 1315 and upload speed of 726, then later download speed of 1320 and upload speed of 734 kbps. The maximum speed is currently set to 4000 kpbs. So no real improvement immediately, but I will monitor it over the day few days.
01-11-2011 10:23 PM
Do you actually need the bell?
02-11-2011 8:03 AM
Quote from: Hollycroft but I will monitor it over the day few days.
Ok, well let us know if you need any more help.
02-11-2011 8:27 AM
Speedtest results are more or less the same this morning, so no improvement yet. How soon might I expect to get faster download speed? I could live without my extension bell, do you think I should take up Jelv's suggestion & get an engineer to remove that?
I have another problem in that I can't get internet connection when my laptop is connecting to the new router wirelessly. My laptop indicates that wireless connection has been established with 'excellent' signal strength. The router's wireless light is green. I can see that there are packets of data being sent between the laptop and the router. Can't see what step I might have missed ....
Many thanks
02-11-2011 9:52 AM
03-11-2011 10:52 AM
I believe that I've got it set up to obtain them automatically, but I've forgotten how to check that. It's a long time ago that I set up my original wireless network with my Linksys router & the new one from Plusnet didn't require much input from me. I have read somewhere that if the wireless key was not input correctly then it wouldn't give me a clear error message to that effect - however, I have tried reentering it & it made no difference.
Still stumped ...
03-11-2011 10:59 AM
I've run a few more speedtests:
Yesterday at 07:10 I got a download speed of 1313 and upload speed of 735 with max achievable download speed of 4000 and IP profile 2561.
Yesterday at 22:45 I got a download speed of 1841 and upload speed of 735 with max achievable download speed of 2000.
Today at 09:40 I got a download speed of 1819 and upload speed of 725 with max achievable download speed of 2000.
So max achievable has been dropped, but actual speed has improved. Is this normal for the initial 3 day settling in period?
