Slow slow and slow
- Slow slow and slow
Slow slow and slow
14-03-2018 10:26 PM
Slow wifi slow customer service. I am not happy. I was told I should be able to leave with cooling off period but on website it says 14 days from sign up and not when it went live. Complete and utter rubbish. Cant even do basics its so slow. Should have known better than to risk switching.
Message 1 of 4
(552 Views)
3 REPLIES 3
Re: Slow slow and slow
15-03-2018 11:30 AM
If the speed you're getting is below estimated speeds provided by PN at outset you have a valid case, but
they're not in control of wifi. Try hard wired connection to the router, and see if that improves.
Additionally if you're using a PN Hub One router try turning off the 5ghz band, and see if that assists?
Lastly you may be suffering interference from neighbours using same frequency as your router; go into router settings
and turn off automatic and set a channel manually; a programme such as the free inSSIDer one will show
what wifi channels are in local use; switch your router to the one LEAST BUSY.
Message 2 of 4
(506 Views)
15-03-2018 11:51 AM
Hard wire all my devices to the router dont make me laugh the wifi is garbage that is that. Im tired of it
Message 3 of 4
(497 Views)
15-03-2018 1:56 PM
Hi there. Our tests aren't finding any issues.
Can you run a BT speedtest at http://www.speedtest.btwholesale.com using a wired connection, completing the further diagnostics at the end? This will store the result on the supplier system and will help us in reporting a fault to our suppliers.
Message 4 of 4
(488 Views)
