Slow since September
- Slow since September
10-12-2014 5:19 PM
an I.P. of 2.16 to 2.39. Since then there has been cut offs due to the poor
weather and BT maintenance. I have tried router resets but nothing I do
improves my current speed of approx. 1900 Kbps and I.P. of 1.68. Router
is a 2700 HGV plugged into the master socket and filters have been changed.
Can someone from Plusnet please give it a kick as it seems to be stuck.
BTW Test
Download speed achieved during the test was - 1.51 Mbps
For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps.
IP Profile for your line is - 1.68 Mbps
Broadband Link Type: Built in modem - ADSL
Connection Type: PPPoA
User Name:
Current Internet Connection:
IP Address: 87.113.72.210
Subnet Mask: 255.255.255.255
Default Gateway: 195.166.128.189
Primary DNS: 212.159.6.10
Secondary DNS: 212.159.6.9
Host Name:
Domain:
MAC Address: --:--:--:--:--:--
MTU: 1500
DSL Details
Modem Type: Built in modem - ADSL
DSL Line (Wire Pair): Line 1 (inner pair)
Current DSL Connection:
Down Up
Rate: 1905 kbs 431 kbs
Max Rate: 1905 kbs 756 kbs
Noise Margin: 7.6 dB 15.6 dB
Attenuation: 60.9 dB 36.1 dB
Output Power: 16.5 dBm 12.4 dBm
Protocol: G.DMT2 Annex A
Channel: Fast
DSLAM Vendor Information Country: {46336} Vendor: {IFTN} Specific: {51313 }
ATM PVC: 0/38
Rate Cap: 1905 kbs
Attenuation @ 300kHz: 60.9 dB
Uncanceled Echo: -21.7 dB Ok
VCXO Frequency Offset: -5.9 ppm Ok
Final Receive Gain: 34.5 dB Ok
Impulse Noise Comp. Tones: 0 Ok
Excessive Impulse Noise: 0 Ok
Traffic Statistics
IP Traffic Bytes Packets Errors %
Transmit: 228303439 2470470 0 0
Receive: -228304702 3381978 0 0
ATM Traffic Cells Errors %
Transmit: 8113213 0 0
Receive: 97949993 0 0
DSL Link Errors
Collected for 11Days5:04:14
Since Current Current Time Since
Reset 24-hr int. 15-min int. Last Event
ATM
Last Event
Cell Header Errors 65689 2347 11 0:00:02
Loss of cell Delineation 1975 125 1 0:03:51
DSL
Link Retrains: 0 0 0 0:00:00
DSL Training Errors: 1 0 0 11Days5:03:38
Training Timeouts: 0 0 0 0:00:00
Loss of Framing Failures: 1 0 0 4Days22:12:59
Loss of Signal Failures: 0 0 0 0:00:00
Loss of Power Failures: 0 0 0 0:00:00
Loss of Margin Failures: 0 0 0 0:00:00
Cum. Seconds w/Errors: 40544 1648 21 0:00:02
Cum. Sec. w/Severe Errors: 2995 121 0 0:14:51
Corrected Blocks: 0 0 0 0:00:00
Uncorrectable Blocks: 203720 8416 24 0:00:02
DSL Unavailable Seconds: 54 0 0 11Days5:03:19
Re: Slow since September
10-12-2014 7:33 PM
You are on quite a long line, which at best might synch at 2.6Mbps.
The current SNRM is an odd figure, sat in the middle between the usual targets of either 6dB or 9dB. If I were to assume that you took the stats at the time you posted, then it would be after dusk and AM/MW radio interference would be present, This rather suggests that the target SNRM is 9dB - higher than normal.
So the question which needs to be addressed to get you more synch speed is why is it elevated? Is there any noise on your phone line? Dial 17070 option 2 using a corded phone plugged into the master socket. Check the line regularly as the noise might be intermittent.
Is the router plugged into the master socket? If not can you please try it there and repost the line stats. What type of master socket do you have?
10-12-2014 10:52 PM
is dis. and qlt is regularly checked and silent. Stats were taken at the time of
posting.
11-12-2014 1:34 PM
If you line is stable, we can look into changes of SNR margin for you, but we'd need your line to be stable to be able to do this.
Tony
11-12-2014 2:50 PM
at the levels I stated in my 1st post. I believe this decrease in speed was caused by exchange
and or line maintenance at the time of some storms. I have been waiting to see if it came back by
itself but it hasn't happened. A SNR reset would be appreciated.
11-12-2014 2:54 PM
11-12-2014 3:46 PM
3 or 6db, I will leave it up to you to do whichever you think will be best.
I know I am on a long line so any improvement will be great.
11-12-2014 4:00 PM
Changes can take up to four hours, but you'll usually see these sooner. Your throughputs won't increase straight away though.
Tony
PS, when this is sorted, if the line remains stable, please let us know if you want your upload uncapping.
11-12-2014 4:10 PM
User Name:
IP Address: 146.199.23.25
Default Gateway: 195.166.130.203
Host Name:
Domain:
MTU: 1500
DSL Details
Down Up
Rate: 2512 kbs 444 kbs
Max Rate: 2512 kbs 588 kbs
Noise Margin: 5.8 dB 13.8 dB
Attenuation: 60.8 dB 36.0 dB
Output Power: 17.3 dBm 12.4 dBm
Channel: Interleaved
ATM PVC: 0/38
Rate Cap: 2512 kbs
Attenuation @ 300kHz: 60.8 dB
Uncanceled Echo: -20.8 dB Ok
VCXO Frequency Offset: 5.7 ppm Ok
Traffic Statistics
Transmit: 18358 249 0 0
Receive: 213878 252 0 0
Transmit: 8854149 0 0
Receive: 105587178 0 0
DSL Link Errors
Collected for 12Days4:15:37
ATM
Last Event
Cell Header Errors 72802 2354 0 0:02:00
Loss of cell Delineation 2228 93 0 0:02:00
DSL
Link Retrains: 1 1 0 0:02:00
DSL Training Errors: 2 1 0 0:01:39
Loss of Framing Failures: 3 2 0 0:02:00
Loss of Signal Failures: 2 2 0 0:02:00
Loss of Margin Failures: 2 2 0 0:02:00
Cum. Seconds w/Errors: 45539 1073 0 0:02:00
Cum. Sec. w/Severe Errors: 3266 124 0 0:02:00
Corrected Blocks: 1540 1540 629 0:00:04
Uncorrectable Blocks: 223838 7638 0 0:02:00
DSL Unavailable Seconds: 96 42 0 0:01:21
Thank you, I'm back to where I was before.
12-12-2014 12:48 AM
Router stats. have improved as shown above but BTW tests show no change
Download speed achieved during the test was - 1.56 Mbps
Do I just have to wait or is there anything that can be done.
regards
12-12-2014 9:42 AM
At the time of your last post your connection hadn't dropped since the profile on our side was updated.
This means your speeds were still being restricted to around the 1.6mbps mark. However your connection dropped in the early hours of the morning so the speeds should now be fine.
Can you retest and get back to us if your still having any issues?
12-12-2014 3:12 PM
Download speed achieved during the test was - 2.08 Mbps
IP Profile for your line is - 2.21 Mbps
Seems ok now,but why is the range still being shown as 0.8 to 2Mbps
12-12-2014 8:51 PM
Quote from: AMX For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps.
It is called the BTOR / BTw get out of jail free card. The top end figure is the most that they think you should dream of for your line and the bottom figure is how poorly they can deliver the service before they will accept that it is unacceptable.
12-12-2014 9:10 PM
12-12-2014 11:30 PM
say perhaps it will update later.
