Slow since I joined
- Slow since I joined
Slow since I joined
07-04-2011 7:19 PM
my old isp when I done speed checks was always 6mb average, sometimes it would hit 8mbs, but I decided to come over to plusnet as they provide an excellent usage meter
On the first couple of days it was hitting 8,, now 1.5mb, which will be absolutely no use when the two older ones come home from uni, they are on VM and get 20mb all the time including TV
Dave
Re: Slow since I joined
08-04-2011 9:04 AM
Welcome to Plusnet and the forum. I'm sure we'll be able to sort that out for you. I'll check a few things and see what I can find out.
Jojo
08-04-2011 9:17 AM
How are you connected to your telephone socket? Are you using an extension socket/cable at all? Would it be possible to plug into the test socket to see if we can get a better sync?
Jojo
08-04-2011 11:17 AM
Remember I have had 2 years with 6 - 8mbs
Dave
08-04-2011 11:38 AM
08-04-2011 11:46 AM
Your sync before you were in the test socket was 2016k. Your sync in the test socket is 8128k. This would indicate a problem with your internal wiring. Once the system sees your higher sync rate your profile will lift to 7150k.
Jojo
08-04-2011 12:45 PM
What internal wiring this computer /router is and has been plugged into the master socket from before I joined plusnet
Dave
want t see a photo?
08-04-2011 1:00 PM
And there is no way I could have rigged that,
Dave
08-04-2011 1:13 PM
Must be the faceplate then, which is also classed as internal. The test socket you're in now is what's known as the demarcation point which is where BT's responsibility ends and yours begins.
Jojo
08-04-2011 2:26 PM
Speed died when I joined plusnet
08-04-2011 2:53 PM
08-04-2011 4:48 PM
08-04-2011 4:50 PM
09-04-2011 3:11 PM
Close to what it was
May (MAY,) have been a bad connection in the "Demarcation Point" as one of the wires broke when I unscrewed it to check for short
Dave
10-04-2011 11:35 AM
