Slow ping times, high latency, overall mbps seems normal.
- Slow ping times, high latency, overall mbps seems ...
09-12-2014 9:19 PM
Hey all, I seem to be experiencing high ping times, but my download speeds seem pretty normal. As requested on the first sticky and some extras, they are on this imgur album:-
https://imgur.com/a/GPeej
Any ideas?
Any ideas?
Message 1 of 7
(961 Views)
6 REPLIES 6
Re: Slow ping times, high latency, overall mbps seems normal.
09-12-2014 9:24 PM
I am on FTTC, I was also on ag03 with bad latency and speeds.
http://community.plus.net/forum/index.php/topic,134809.new.html#new
But not as high as 300ms.
I hopped to ag01 and seems good again.
ag03
ag01
ag03
ag01
Message 2 of 7
(577 Views)
09-12-2014 9:45 PM
Hopped on? Are you implying I can change my gateway?
Message 3 of 7
(577 Views)
09-12-2014 9:50 PM
yes, on my asus since I have to do this so much on plusnet I actually made a shell script to do it
basically you disconnect the ppp session, wait 10 seconds or so then recconnect, After recconecting I would wait at least another 30 seconds to give it time to connect.
admin@RT-AC66U:/tmp/mnt/OPTWARE# ./ppp.sh
old ppp pid is 20693
Plugin rp-pppoe.so loaded.
RP-PPPoE plugin version 3.11 compiled against pppd 2.4.5
new ppp pid is 20819
Message 4 of 7
(577 Views)
09-12-2014 9:56 PM
Can confirm, just switched to ag05 and my issues are gone.
Thanks for the tip
EDIT: nevermind they are back. It was fine for a short period
Thanks for the tip
Message 5 of 7
(576 Views)
09-12-2014 9:59 PM
Something that I have only just realized, it is really windy here atm, it might not be helping me much. I'll report back when its over.
Message 6 of 7
(576 Views)
10-12-2014 10:49 AM
Hi there.
Testing is showing no physical issues with your line and there's no capacity issues in your area.
There was a issue with the gateway you were on but that's been resolved.
Can you monitor it tonight and if your still having issues let us know?
Message 7 of 7
(576 Views)
