Slow forums? - SOLVED
- Re: Slow forums?
18-07-2012 6:25 AM
Morning all
Is it just me, or have these forums suddenly become extremely slow to load? All other sites are working perfectly, but searching or viewing a post on here is taking up to a minute at a time.
Edit - submitting is instantaneous, though.
Message 1 of 6
(920 Views)
5 REPLIES 5
Re: Slow forums?
18-07-2012 7:53 AM
Not noticed anything different from normal, just the usual glitches.
Message 2 of 6
(421 Views)
Re: Slow forums?
18-07-2012 8:28 AM
Thanks for that - but I'm still suffering from 'walking through treacle' loading on here, everything from logging in onwards takes forever. As an aside, I've also had problems with email collection. Mailwasher reporting timeouts, and Tbird again taking ann age to connect to mail.plus.net.
Would a gateway hop do anything to help?
Message 3 of 6
(421 Views)
Re: Slow forums?
18-07-2012 9:05 AM
Possibly, probably, but check which Gateway you are on first so you can report that problem if a Gateway hop solves it. However, are you connected to the modem/router by ethernet cable or wireless. If wireless it could be problems with that particular wireless channel. Run some speed checks first - BT speedtester, Thinkbroadband, Mybroadband speed etc to confirm whether it's connection issues or just this site.
(If you go to Gateway hop - do so by Disconnecting then reconnecting your PPP Internet session in your modem/router Interface - not by a reboot!).
Message 4 of 6
(421 Views)
Re: Slow forums?
18-07-2012 10:05 AM
Sorry for the gap in replying Anotherone - bad night = quick nap - but having left everything for an hour or so, it all seems to have come back normal, including MW.
Will keep my eye on things between other activities, but I'm not going to be on here a lot today.
Message 5 of 6
(421 Views)
Re: Slow forums?
18-07-2012 5:23 PM
FYI, Anotherone - solved! It was the work on ptn-ag04.
Sorry I didn't post earlier, as soon as I found it, but had to go out.
Message 6 of 6
(421 Views)
