Slow fibre speed
Kevstar
Slow fibre speed
Hi im getting a slow fibre speed in comparison to what we were quoted and usually get. we usually get around 40 but now 11.
Could someone help with this please.
Thanks in advance, Kev
9 REPLIES 9
Fixes: 357
Re: Slow fibre speed
@Kevstar
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
Kevstar
Just waiting for a reply from the text service as its testing for faults.
Fixes: 357
Let us know what it says.
Kevstar
Hi jab, they found a fault but are closed now so ill contact them again tomorrow, thanks for your help Smiley
Fixes: 357
Fair enough, @Kevstar . If they found a fault, they should initiate remedial procedures without you having to contact them.
Kevstar
They kind of did but it said they need to talk to us and to text ADVISOR but with in opening hours Smiley
Fixes: 357
OK - probably need to arrange an engineer visit, then.
willcutforth
Fixes: 113
I can see you have got this arranged @Kevstar do you need me to do anything from my side at this point?
 Will Cutforth
Kevstar
No thanks and its all fixed already, Good stuff Plusnet for fixing so quickly Smiley
