Slow download, upload...everything
- Slow download, upload...everything
Re: Slow download, upload...everything
18-12-2010 6:09 PM
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 14,227 / 1,508
Bandwidth (Up/Down) [kbps/kbps]: 447 / 1,432
Data Transferred (Sent/Received) [GB/GB]: 1.01 / 211.99
Output Power (Up/Down) [dBm]: 12.5 / 19.5
Line Attenuation (Up/Down) [dB]: 30.0 / 47.0
SN Margin (Up/Down) [dB]: 5.5 / 6.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 184 / 0
FEC Errors (Up/Down): 1,945 / 637
CRC Errors (Up/Down): 17,615 / 8
HEC Errors (Up/Down): NA / 13
18-12-2010 6:23 PM
18-12-2010 6:31 PM
This clearly shows a fault but where it is I have no idea.
Until this gets sorted you won't get anywhere and it probably won't be until there is a BT engineer visit
As a comparison I have a much longer line than you and my upstream attenuation is only 20dB
24-12-2010 1:50 PM
So they haven't been investigating anything??
This fault finding thing needs a total overhaul.
24-12-2010 2:18 PM
I'm sorry to see that you're still having issues. I've just asked a faults agent to take a look at this for you.
Jojo
24-12-2010 3:49 PM
What is also adding to the stress is the fact that my speed HAS improved but I am still getting disconnections. Without getting to the root cause , I know the speed will plummet again. And I keep being asked the same questions by seemingly different people.
:)Well, back to work. Many thanks, and.
Happy Christmas everyone.
24-12-2010 3:57 PM
You're in good hands with Riyaz, he's raised the fault for you and there's a couple of questions awaiting your attention when you next check your email - soon as that's done I'm given to understand there'll be an engineer booked next week for you.
24-12-2010 9:26 PM
Have a great christmas.
27-12-2010 5:46 PM
I have had several days of terrible connection problems. Disconnections and my speed dropped down so low- it looks up to gary glitter!!
I have put my broadband firewall back on, back to low setting. I feel it can't make things any worse. Can anyone tell me if I should or not ,do this? I was asked to turn it off while checks were carried out, and things seem to be worse.
Also, on the BT site, it seems fibre is going to be available here in March next year. Would fibre be better than broadband Ihave now?Or is it totally independant? And could I sign up on PN for this?
I have been with PN for 3 months, and had terrible problems with connection and am thinking that in 3 months time it may all be irrelevant.
Any views, anyone, please?
30-12-2010 2:39 PM
House checked ok, 8Mb to cabinet 400 yds away. Dropping signal at my door.
A little bit of magic and now a clear 8Mb to my door. All seems ok in house now. ( can't help myself with all these smileys :))
Any chance of resetting my profile, though at moment is on approx 1Mb download speed. The router has been unplugged several times today - is this likely to be interpreted as disconnections, hence a fault, by BT? Am I going to get my speed reduced again? Thats my worry now.
But otherwise , very happy ( so-far, long may it last).
30-12-2010 2:41 PM
Link Information
Uptime: 0 days, 0:27:43
Maximum Bandwidth (Up/Down) [kbps/kbps]: 19,601 / 9,540
Bandwidth (Up/Down) [kbps/kbps]: 446 / 9,046
Data Transferred (Sent/Received) [MB/MB]: 2.42 / 23.90
Output Power (Up/Down) [dBm]: 12.5 / 20.0
Line Attenuation (Up/Down) [dB]: 24.5 / 40.0
SN Margin (Up/Down) [dB]: 15.0 / 6.0
FEC Errors (Up/Down): 17,190 / 8,233
CRC Errors (Up/Down): 61,364 / 36
HEC Errors (Up/Down): 35,640 / 691
Got so excited , I forgot..
30-12-2010 2:56 PM
Great news. I'll see what I can do about the profile.
Jojo
30-12-2010 3:07 PM
I've changed the profile to 7000k. Give it about 15 mins to change and if it's not changed then reboot via the router interface.
Jojo
30-12-2010 9:28 PM
Quote from: rogadodge Line Attenuation (Up/Down) [dB]: 24.5 / 40.0
As you were having problems with these values swinging around wildly, I'd suggest watching these values to see whether they have now stopped fluctuating.
And to answer your question about fibre... the answer is that with the fault lying between the cabinet & your house, then you'd still have had a problem. I'm not sure about how the VDSL2 management scheme would have coped, but it is possible that BT could have seen a low speed (below 15Mbps) and refused to provision FTTC at all.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
31-12-2010 9:00 AM
I am having some slow speeds too and I am waiting for PN to investigate, tum te tum.
Any tips would no doubt prove to be very useful.
Cheers
