Slow download speed, but fast upload?
- Re: Slow download speed, but fast upload?
27-08-2012 10:16 PM
I am on the Plusnet Fibre Extra product, the one with 80/20 download/upload speed and current speed tests show that I am getting 30mb download and close to 19mb upload. The speed estimate on my account shows close to 60mb download. What should I do to diagnose the speed problem?
Message 1 of 6
(3,415 Views)
5 REPLIES 5
28-08-2012 8:53 AM
Greg,
sorry i can't help you but i've just switched to the 80/20 service from the 40 version .... i was getting 36/1.5 ... now i'm getting 35/17 ! I guess we're going to have to call customer services ...
Andy
Andy
Message 2 of 6
(1,349 Views)
28-08-2012 11:31 AM
Followed advice written elsewhere and powered of the modem for 10 minutes and it has resynced at 64/16
I'd suggest you do the same ... shame the email from plus.net didn't say this needed to be done ....
Andy
Andy
Message 3 of 6
(1,349 Views)
28-08-2012 11:43 AM
Hi................I also changed my account from 40/10 and my download speed is down for last few days.......Did a reset on both modem and router and no change.......Roger
Message 4 of 6
(1,349 Views)
28-08-2012 12:00 PM
Hi G3YBO,
Are you using a wired or wireless connection? Your profile is set correctly, if you are using a wired connection then I would suggest raising a fault at http://faults.plus.net If not then please try with a wired connection and see if there is any difference.
Chris
Chris
Message 5 of 6
(1,349 Views)
28-08-2012 5:09 PM
Also, if any of you are connected to your router via powerline, I suggest you connect directly to the router with an Ethernet cable and re run the speed test. I did a speed test with my 200mbps powerline kit and maxed out at 30mb, but I just tried connecting directly to the router and it was hitting 60mb. I guess I need to update my connection to the router. I am using the TP-Link AV200 200Mbps Mini Powerline Starter Kit and it just cannot deal with the speeds
Significant difference in speed when using direct wired Ethernet vs powerline Ethernet
Message 6 of 6
(1,349 Views)
