Slow download, not existent upload
_gc
All,
Been having a load of problems with my broadband over the last few months that required a ticket to be raised and the line to be reset (with an "identified fault") probably once or twice every week. Not ideal but it was manageable.
This week is a different story.
Starting Monday, particularly between the hours of 8:00-10:00AM and 14:00+ the internet is just completely unusable (particularly the fact that upload is a constant 0 as I need to remote for work). I've been in contact with a tech representative earlier who identified an intermittent problem and a flag that suggested that the master socket's faceplate was getting an intermittent connection - the solution being that we went through the process of moving my router from the extension socket to the master's test socket.
This was all good for about 30 minutes until the problem resurfaced and again, the internet is now completely unusable. A reset of the router seems to give about 2 minutes of genuine Download 10mbps+, Upload ~1mbps but then reverts back to having issues.
I've tried all of WiFi, power line (usual setup) and ethernet.
It's in an apartment block and nobody else around me has reported any issues after chatting to a few.
The outcome of the call with the tech representative was to leave the router in the master's test socket for 3 days to gather data - does this mean I have to live with these problems until Saturday (so Monday at this point) before any further investigation can take place? I currently can't work.
Router -
1 - Product name:Plusnet Router
2 - Serial number:N7192141B014518
3 - Firmware version:7.275.11_F2704N_Plusnet
4 - Board version:F@ST2704N
5 - ModeADSL
6 - Uptime:0 days 00:36:22
7 - Data rate:1080/19423
8 - Maximum data rate:1468/19744
9 - Noise margin:5.9/6.1
10 - Line attenuation:6.6/13.5
12 - Data sent/received:84.1M/78.3M
20 - Broadband username:
21 - Wi-Fi network/SSID:
22 - Wi-Fi connections:Enable(802.11 b/g/n(up to 144 Mb/s))20 MHz WPS enabled
23 - Wi-Fi security:WPA2
24 - Wi-Fi channel:Automatic (Smart Wireless)
25 - Firewall:Default
26 - MAC Address:ec:be:dd:2f:aa:5b
27 - Software variantVersion 1.0
28 - Boot loader:7.275.11
Speedtests (using https://www.speedtest.btwholesale.com/details all within the last 10 minutes, one after another) -
ATTEMPTPINGDOWNLOADUPLOAD
16200
226003.490
3000
4183700
53253.380.85
2 REPLIES 2
Mustrum
Fixes: 73
Re: Slow download, not existent upload
Have you tried just the router in the test socket, and your PC direct to the router?
It sounds like you are suffering from congestion, quite possibly caused by someone else in the block also using powerlines and they are connecting via the mains to your network.
Unless you can use encryption on the powerlines, they are not a good idea in a block.
_gc
Yeah I switched to that Monday afternoon when these major problems first popped up but neither WiFi or ethernet directly to the router sees any difference.
