Slow download and upload speed
shaaaaaake
For at least the last few weeks my download speed has been between 23-33Mb (estimated 42-61, guaranteed 37) and upload speed has been around 8Mb (estimated 9-14).  I have Unlimited Fibre Extra.  Can someone please rectify this so I can get the speeds I'm paying for.
2 REPLIES 2
Legend
Fixes: 254
Re: Slow download and upload speed
@shaaaaaake As a start:
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub would be a good starting point.
For the Hub One -
For the Hub Two -
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
adamwalker
Fixes: 221
Hi there @shaaaaaake
I've just been taking a look into this for you, line tests are reflecting the slow speeds you mentioned but don't show us any obvious causes for the issue.
Can you try following the checks @jab1 recommended next? Please let us know how you get on. - Adam
 Adam Walker
