Slow down after my holiday
anniesboy
I switched my router off while on holiday for two weeks. Its been back on for four days.
BT profile is  3.67    Plusnet showing 2.6
Current speed is around  2.4.
Will a disconnect / reconnect at router help ,or does it need a nudge at Plusnet end
Fixes: 69
Re: Slow down after my holiday
Hi  anniesboy,
A line tests shows me a line rate of 3669kbps so I've adjusted our profile in line with that for you, so you shouldn't need to reboot.
Let me know if you have any other concerns.
Adam
 Adam Walker
anniesboy
Many thanks Adam, that's brought it back to normal (for me)
