Slow connection tonight.
- Slow connection tonight.
- « Previous
- 1
- 2
- Next »
Re: Slow connection tonight.
01-05-2013 5:46 PM
@Totalguy
Who asked your opinion
And if you re read mine went down to 5mb so does that count
Message 16 of 19
(216 Views)
01-05-2013 6:22 PM
5Mb - if only
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 17 of 19
(216 Views)
01-05-2013 6:36 PM
Message 18 of 19
(216 Views)
01-05-2013 7:07 PM
Is that constant, or just at peak times. If constant, you'd better -
Run the BTw Performance test (ignore the red preamble except make sure no other programs are using the Internet) and at the end of the first run, click the Further Diagnostics button, enter just your Phone number and Run the Further Diagnostics Test. Do a Copy and Paste of the results and post here (no need to grab an image).
Check your Current Line speed (Login required)
And I'm not going to offer to swap my 6Mbps (usually 6.5) with some of you then
Message 19 of 19
(216 Views)
- « Previous
- 1
- 2
- Next »
