Slow connection + Ping, but sync speed fine
- Slow connection + Ping, but sync speed fine
Re: Slow connection + Ping, but sync speed fine
01-02-2015 3:29 PM
01-02-2015 3:53 PM
Bala (next exchange along) wasn't upgraded to 21CN before it got FTTC, so I very much doubt we'll see it. Interesting to see that we're a child exchange for Dolgellau, as The ducting laid for fibre (50mm laid inside existing ducting) came from Bala rather than Dolgellau.
@Araf
Are you on a long line out of the village?
01-02-2015 3:56 PM
A lot of BT users were complaining of slow speeds in the village pub last night including the pub which went to fibre on Friday!
01-02-2015 4:13 PM
Quote from: Araf No I live in the village not too far from the exchange.
I thought they were changing over next friday? The wifi's certainly still on the old ADSL line (I've told them to let me know when fibre arrives to I can swap it over to the new line)
01-02-2015 4:23 PM
01-02-2015 4:24 PM
01-02-2015 5:10 PM
Quote from: rhydsnewi Bala (next exchange along) wasn't upgraded to 21CN before it got FTTC, so I very much doubt we'll see it. Interesting to see that we're a child exchange for Dolgellau, as The ducting laid for fibre (50mm laid inside existing ducting) came from Bala rather than Dolgellau.
It's a bit of a mystery then as Bala is a child of Corwen.
01-02-2015 6:28 PM
01-02-2015 10:27 PM
Up to date example from me at 22:25 on 01/02/15
google.co.uk
Packets: Sent = 20, Received = 20, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1302ms, Maximum = 1804ms, Average = 1478ms
bbc.co.uk
Minimum = 1306ms, Maximum = 1735ms, Average = 1518ms
With these pings I might as well be on satellite broadband!
01-02-2015 10:33 PM
Download speedachieved during the test was - 0.1 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 7.15 Mbps
02-02-2015 9:39 AM
02-02-2015 9:55 AM
The problem is I'm moving to fibre on friday, is there any way of keeping the ticket open beyond then if there are still slow connections in the village? As previously mentioned my work has a Plusnet Business line on the same exchange that's similarly affected.
02-02-2015 6:07 PM
18:01 on 02/02/15
bbc.co.uk
Packets: Sent = 20, Received = 19, Lost = 1 (5% loss),
Minimum = 551ms, Maximum = 1513ms, Average = 990ms
google.co.uk
Minimum = 662ms, Maximum = 1433ms, Average = 963ms
Line test
Download speedachieved during the test was - 1.11 Mbps
Still not working at what it should.
03-02-2015 10:03 AM
The broadband fault has been closed by the supplier. Should problems re-occur, please restart the Broadband Fault Checker."
Does this mean I have to start from the beginning again?
03-02-2015 4:22 PM
they are going to have a word with the suppliers!
