Slow connection + Ping, but sync speed fine
- Slow connection + Ping, but sync speed fine
Re: Slow connection + Ping, but sync speed fine
30-01-2015 11:38 AM
30-01-2015 12:44 PM
30-01-2015 1:30 PM
I would be shocked if this issue is resolved for you before you're scheduled to get fibre next week.
30-01-2015 4:40 PM
dick:quote
30-01-2015 4:49 PM
Quote from: plusnettony Someone will be here tomorrow.
In that case I will attempt to get average Pings on all three work ADSLs and mine at around 8pm tonight to both google.co.uk and bbc.co.uk
Current average ping to google.co.uk (16:42 30/01/15)
Packets: Sent = 20, Received = 20, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 176ms, Maximum = 531ms, Average = 336ms
30-01-2015 5:14 PM
If you can collect usernames, if problems exist, and if they are on the same exchange, PM whoever is on here tomorrow and they can start to collate the data. Once we have enough examples, we'll raise the pro-active case.
30-01-2015 7:55 PM
google.co.uk
Minimum = 853ms, Maximum = 1072ms, Average = 980ms
bbc.co.uk
Minimum = 625ms, Maximum = 1088ms, Average = 887ms
30-01-2015 7:58 PM
google.co.uk
Minimum = 471ms, Maximum = 1053ms, Average = 718ms
bbc.co.uk
Minimum = 649ms, Maximum = 1206ms, Average = 872ms
30-01-2015 8:08 PM
google.co.uk
Minimum = 437ms, Maximum = 1332ms, Average = 785ms
bbc.co.uk
Minimum = 244ms, Maximum = 900ms, Average = 534ms
30-01-2015 8:13 PM
Cardiff and south Wales Increased peak time latency and reduced speed AF-MF-28243 12/1/15 Work completed to fix on Monday evening, monitoring 90% of customers in the South Wales area 12/1/15
Is it possible that this is connected to our issue here in North Wales?
01-02-2015 9:52 AM
google.co.uk
Minimum = 830ms, Maximum = 1138ms, Average = 970ms
BBC.co.uk
Minimum = 672ms, Maximum = 1099ms, Average = 924ms
Its getting to the point now that iPlayer radio is struggling, let alone anything else.
01-02-2015 1:53 PM
Exchange - LLANUWCHLLYN
SVLAN - Total of 2 VPs. This circuit is currently on NCIF411200 which is showing BLUE.
VP Data - Blue - 1 , Green - 0 , Amber - 1 , Red - 0
TAGs (Clean): 7 to 8 Mbps (Fibre available)
Am I right in thinking that Blue = "working normally" and amber is "medium congestion"? So our local exchange has one VP that's running at or near capacity?
01-02-2015 1:59 PM
From best to worst - blue, green, amber and red.
I suspect the issue is beyond the SVLAN/VLAN and in the actual backhaul. This isn't something Plusnet have direct monitoring data to see though.
01-02-2015 2:20 PM
Just to check, am I right in thinking that FTTC doesn't rely on the existing exchange's backhaul?
01-02-2015 3:26 PM
Llanuwchllyn is a child exchange of Dolgellau for FTTC - so that might mean that Llanuwchllyn will not be upgraded for 21CN itself and that FTTC will be provided over 21CN directly from Dolgellau.
The normal process used to be 20CN > 21CN > FTTC/P for an exchange...but some exchanges skip the 21CN upgrade if they have another exchange that's close and has already been upgraded to 21CN.
