Slow connection + Ping, but sync speed fine
- Slow connection + Ping, but sync speed fine
26-01-2015 9:48 PM
Basically, my broadband speed has dropped from 6-odd mbit to 3.5mbit, while ping times to google have risen from around 30-40ms up to 600ms at times, but usually around 300-400ms
I've tried a different router with no change. The ADSL line stats show a solid 8128/448kbs link (as usual) with a solid noise margin.
Here's the results of a number speedtests I have performed recently
BT Wholesale speed test (basic)
Download speed (Mbps): 3.54
Upload speed (Mbps): 0.16
Ping latency(ms): 277
BT Wholesale speed (advanced)
Download speedachieved during the test was - 3.54 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 7.15 Mbps
Plusnet esitmated line speed:
Estimated line speed:
8Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-01-22 09:33:59
Current line speed:
7.15 Mb
This has come on the last few days. I have ordered a fibre upgrade if that's in any way connected
Any ideas anyone?
Re: Slow connection + Ping, but sync speed fine
26-01-2015 9:54 PM
26-01-2015 10:38 PM
26-01-2015 10:58 PM
I'll re-check my pings off-peak to compare
27-01-2015 7:38 AM
I'll re-check during peak time tonight but it certainly seems like a contention/congestion issue somewhere.
27-01-2015 9:17 AM
I've also noticed it in the last week or so. Sounds like a very similar issue, both on 20CN
27-01-2015 9:28 AM
27-01-2015 10:38 AM
27-01-2015 1:29 PM
27-01-2015 2:45 PM
27-01-2015 5:22 PM
192.168.1.254 (router as a baseline)
Packets: Sent = 20, Received = 20, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 7ms, Average = 3ms
www.bbc.co.uk
Minimum = 380ms, Maximum = 1110ms, Average = 710ms
www.google.co.uk
Minimum = 325ms, Maximum = 706ms, Average = 511ms
As an aside, pings to google this morning (8am) were around 20-30ms, so it seems to be a contention/peak time issue.
27-01-2015 7:19 PM
Router:
Minimum = 2ms, Maximum = 4ms, Average = 3ms
bbc.co.uk
Packets: Sent = 20, Received = 19, Lost = 1 (5% loss),
Minimum = 969ms, Maximum = 1405ms, Average = 1168ms
google.co.uk
Minimum = 666ms, Maximum = 1226ms, Average = 955ms
27-01-2015 8:24 PM
google.co.uk
Minimum = 741ms, Maximum = 1040ms, Average = 898ms
bbc.co.uk
Minimum = 900ms, Maximum = 1776ms, Average = 1257ms
This is definitely an error/fault condition now. I will re-check in the morning to show the difference in latency
27-01-2015 10:43 PM
google.co.uk
Minimum = 22ms, Maximum = 220ms, Average = 43ms
bbc.co.uk
Minimum = 23ms, Maximum = 164ms, Average = 43ms
27-01-2015 10:53 PM
google.co.uk
Minimum = 216ms, Maximum = 674ms, Average = 442ms
bbc.co.uk
Minimum = 648ms, Maximum = 1105ms, Average = 904ms
