Slow conection speeds
- Slow conection speeds
02-01-2008 3:35 PM
I have checked my router setup, my phone lines and everything else that I can think of and still get poor results, not good when I am trying to use my connection for gaming!!
Any suggestions or help that anyone can think of?
Re: Slow conection speeds
02-01-2008 3:40 PM
Unless it's your modem/router or filters being really, really, dodgy, it looks like a problem at the exchange.
Can you please just try using a different filter, connecting into the master socket by a filter and trying a different modem if at all possible?
Let me know how you get on and then I can rerun some tests and see how things look then.
02-01-2008 3:44 PM
I have tried a different modem, but that made no difference at all. I will, however, try a different filter and see if that makes a diference at all.
02-01-2008 3:45 PM
Do you still have that other modem there? I just want to be able to see if it makes any noticeable change in your synchronisation speed, which appears to be causing the problems.
02-01-2008 4:08 PM
02-01-2008 4:11 PM
Massive improvement
Downstream Sync is now 8096Kbps, with upstream being 448Kbps.
If you leave things as they are for the next three days, then you should see a considerable improvement in your speeds, hopefully to the region of 6-7Mbps.
Sounds like your old modem may serve out the rest of its days as a paperweight.
02-01-2008 4:13 PM
Quote from: Jameseh Sounds like your old modem may serve out the rest of its days as a paperweight.
Recycle! Recycle! Recycle!
Find someone you dislike and gift it to them!
B.
(p.s. - I am only joking, obviously
02-01-2008 4:17 PM
05-01-2008 1:31 AM
07-01-2008 2:34 PM
Can you try rebooting your router for me?
We're now seeing you as having a 6500Kbps IP Profile, so it should be considerably better now.
