Slow but steady
- Slow but steady
Slow but steady
09-07-2012 9:02 PM
I've done all the usual tests and all seems fine
Re: Slow but steady
09-07-2012 9:34 PM
Re: Slow but steady
09-07-2012 9:44 PM
Re: Slow but steady
09-07-2012 9:46 PM
Re: Slow but steady
09-07-2012 10:07 PM
Re: Slow but steady
09-07-2012 10:44 PM
Re: Slow but steady
09-07-2012 10:48 PM
Account Name DG834Gv5
Firmware Version V1.6.01.34
ADSL Port
MAC Address <snip>
IP Address 91.125.98.154
Network Type PPPoA
IP Subnet Mask 255.255.255.255
<snip>
Domain Name Server
212.159.6.9
212.159.6.10
LAN Port
MAC Address <snip>
IP Address 192.168.0.1
DHCP ON
IP Subnet Mask 255.255.255.0
Modem
ADSL Firmware Version E.25.41.64 A
Modem Status connected
DownStream Connection Speed 1600 kbps
UpStream Connection Speed 448 kbps
VPI 0
VCI 38
Wireless Port
MAC Address <snip>
Name (SSID) <snip>
Region Europe
Channel 3 (Auto)
Wireless AP ON
Broadcast Name ON
[Moderator's note by Jim (Oldjim) connection identification removed mod:end
Re: Slow but steady
10-07-2012 2:34 AM
You need to Click on the "Show Statistics" button and the page you want will contain Attenuation and Noise Margin as well as the Connection Speed. Alternatively this link should work http://192.168.0.1/setup.cgi?next_file=stattbl.htm
Re: Slow but steady
10-07-2012 6:27 AM
Port Status TxPkts RxPkts Collisions Tx B/s Up Time
WAN PPPoA 14848 15218 0 40 95 10:02:46
LAN 100M/Full 148792 140509 0 430 375 10:02:58
WLAN 11M/54M 372468 234674 0 12687 689 10:03:19
ADSL Link Downstream Upstream
Connection Speed 1600 kbps 448 kbps
Line Attenuation 63.5 db 31.5 db
Noise Margin 9.5 db 10 db
I've copy and paste so hope you can make sense without the grid
Re: Slow but steady
10-07-2012 11:27 AM
I've just run some tests and it seems like something happened a couple of days ago to increase your SNR, which has subsequently brought the sync speed down. Can you think of anything that might have caused it, because tests indicate some interference at the premises.
Jojo
Re: Slow but steady
10-07-2012 1:28 PM
Re: Slow but steady
10-07-2012 2:29 PM
Re: Slow but steady
10-07-2012 4:19 PM
I'd fully expect a Netgear to readily handle those sort of daily variations.
Re: Slow but steady
10-07-2012 4:40 PM
Re: Slow but steady
12-07-2012 10:29 AM
