Slow broadband
- Slow broadband
Slow broadband
03-11-2007 8:39 PM
upgraded my account to plusnets 8mb adsl some months ago my router says it connect at 8 mb but its still stuck on 2mb on my connection settings
Any help?
Any help?
Message 1 of 6
(1,950 Views)
5 REPLIES 5
Re: Slow broadband
03-11-2007 8:52 PM
have you run a speedtest on the bt site to see what your IP profile is?
I know your connection settings say 2Mb, but it's what the IP profile says that's important. If your IP profile is showing as 2Mb then raise a ticket with the CSC team, and they should give it a nudge. If you don't have any joy then I'll give the appropriate people a kick for you.
Roger.
Roger.
Message 2 of 6
(488 Views)
Re: Slow broadband
03-11-2007 9:06 PM
got this from my speedtest
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 6500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 7616 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1812 kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
Message 3 of 6
(488 Views)
Re: Slow broadband
03-11-2007 9:12 PM
Yep.. raise a ticket and ask them to reset your IP profile for you. I think you should see a IP profile of around 6500 on that sync speed.
Roger.
Roger.
Message 4 of 6
(488 Views)
Re: Slow broadband
04-11-2007 4:45 PM
Apologies for not picking this up - it appears the ticket was actioned last night shortly after being raised. If you haven't already you'll need to disconnect and reconnect in order to get the new updated profile.
Message 5 of 6
(488 Views)
Re: Slow broadband
04-11-2007 5:30 PM
Thanks for the update Matt.. seems the OP hasn't posted back, so one would assume that all is well again...
Message 6 of 6
(488 Views)
