Slow broadband speed
- Slow broadband speed
06-06-2010 4:02 PM
Can anyone spot the probable cause? Thanks.
[quote=BT speed tester] Download speedachieved during the test was - 228 Kbps
Additional Information:
Your DSL Connection Rate :4160 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 3000 Kbps
[quote=Router statistics]Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 294104 322631 0 1258 3104 29:14:24
LAN 10M/100M 162656 42254 0 546 48 29:45:40
WLAN 11M/54M 396419 266452 0 2798 1248 29:45:32
ADSL Link Downstream Upstream
Connection Speed 4160 kbps 448 kbps
Line Attenuation 52.0 db 30.0 db
Message 1 of 3
(620 Views)
2 REPLIES 2
Re: Slow broadband speed
06-06-2010 5:11 PM
Three questions
What does this give for current line speed https://portal.plus.net/my.html?action=data_transfer_speed
Are you connecting to the router by wires or wireless
Have you reached your usage limit
Message 2 of 3
(300 Views)
06-06-2010 7:19 PM
and what's your exchange status http://usertools.plus.net/exchanges/ , red or green ?
Message 3 of 3
(300 Views)
