Slow broadband speed ...
thanaset
Hello.
My broadband speed is currently around 350Kbps. It used to be around 450Kbps-600Kbps. I haven't noticed the speed drop until now. I was wondering if there's anything that can be done to fixed this? Thank you.
Thanaset
1 REPLY 1
MatthewWheeler
Fixes: 437
Re: Slow broadband speed ...
Sorry to hear your speeds have dropped.
Our tests aren't showing any cause for this so I'd recommend going through the troubleshooting here
If you're still having issues after raise a fault here and we'll investigate further
 Matthew Wheeler
