Slow broadband and landline switchover
- Slow broadband and landline switchover
22-11-2023 10:20 AM
Re: Slow broadband and landline switchover
22-11-2023 10:27 AM
@LouiseL You say you have 'fibre to the cabinet', and then say there 'is no fibre in the area'. Do you mean you have ADSL?
If you are concerned about the loss of the PSTN, you could explore the option - now - of a VoIP service, there are a number of firms who will supply this, and your current speeds, although very low, are sufficient.
22-11-2023 10:34 AM
22-11-2023 10:37 AM
Unfortunately - as things stand, but there could be changes between now and when the PSTN is finally switched off - in any case, unless you are constantly on the phone, it will have little effect on your situation.
22-11-2023 10:41 AM
22-11-2023 5:00 PM
Having checked your postcode, it appears you do have FTTC (rather than ADSL), but as you say it is quite slow.
For PSTN switch-off, VoIP can be used over slow broadband connections such as yours - it works comfortably with only 0.1Mbps. However, Plusnet don't offer VoIP - so they are quite likley to offer to move you to BT or EE.
Alternatively you could choose to use a 3rd party VoIP company, or move to a non-BT family ISP that offers both VoIP and broadband.
Unfortunately, your broadband speed won't get better until some company builds FTTP to you - have you checked what mobile coverage the various companies provide?
22-11-2023 5:49 PM
"have you checked what mobile coverage the various companies provide?"
Try putting your postcode into OFCOM's checker and then selecting your address:
http://www.ofcom.org.uk/mobile-coverage
As you say, service in your area doesn't appear to be very good.
22-11-2023 7:45 PM
