Slow broadband & high packet loss
- Slow broadband & high packet loss
04-11-2008 9:36 PM
Hi
I have noticed significantly slower broadband today. I do not check all the time, but it was verty slow today so I did and I have managed to achieve around a miserable 480 kb/s - 500kb/s . Normally I can get between 2 & 3.5 Mb/s. Actual sync speeds seem fine at 4928 kb/s down and 640 kb/s up. i.e normal. Packet loss pinging next hop address 195.166.128.93 is about 5-10%. Ping times are about 100 - 200ms!.
This has been going on for some hours. No sign of any improvement.
Any ideas ?
Any ideas ?
Message 1 of 5
(1,228 Views)
4 REPLIES 4
Re: Slow broadband & high packet loss
04-11-2008 9:39 PM
you could look at this thread http://community.plus.net/forum/index.php/topic,69514.msg558795/topicseen.html#new
Message 2 of 5
(396 Views)
04-11-2008 10:01 PM
Thanks pierre_pierre
It's good to know I'm not alone!
In the last 5 mins it seems that someone has thrown a switch and I can now get 4Mb/s - ping times down, packet loss gone....
Cheers
PB
Cheers
PB
Message 3 of 5
(396 Views)
04-11-2008 10:58 PM
Those speeds really don't look good. The changes we made to try to resolve the issues will clear themselves at 11 so it should go back to normal. I'll pass your feedback on to the traffic management gurus and see what they come up with next.
Message 4 of 5
(396 Views)
07-11-2008 9:01 PM
Thanks Chris
I'm afraid it's not good tonight either so the guru's have failed!
Similar symptoms. lousy speed, packet loss, etc
Download 228kb/s 😞
Upload 305 kb/s
It feels very laggy as you can imagine.
PB
Message 5 of 5
(396 Views)
