Slow broadband....again!
Damian78
Hi all,
Had some issues with my speed the other week but line tested fine and it seemed to be ok.
This morning it seemed slow so I reset the router, then disconnected and swapped out my ADSL Nation faceplate for the standard BT Openreach.
Seemed fine but now its crawling and Speedtest sites won't work.
Can my line be checked? Also is interleaving off and my ping should be quite low and its not as I have the £5 priority connection enabled too
Fixes: 76
Re: Slow broadband....again!
I can see a fair few drops from this morning and it looks like you might not have reconnected yet:
<img src="http://community.plus.net/visualradius/generated/image13977339337121.png"/>
If you can reply back when you're back online please and I'll get the line reset.
 Adam Walker
Damian78
I'm back on now.....I hope
Fixes: 76
OK, cheers I've submitted the reset. I'll be checking back in 30 minutes or so to see if I can update the speed profile.
 Adam Walker
Damian78
Think thats sorted it.
No FEC errors now and about 6.3meg downloads.
Ta
Fixes: 76
Good stuff, I've just been able to up the profile to 6600kbps.
 Adam Walker
