Slow XBLM, PSN, Itunes Store downloads after 6pm
- Slow XBLM, PSN, Itunes Store downloads after 6pm
Re: Slow XBLM, PSN, Itunes Store downloads after 6pm
26-03-2009 11:45 PM
i was on pte-ag2 tonight and before i put some hours into cod waw i gave a few streams ago to see if they where still runing smooth and found they would not buffer new ones and old streams.
so jumped on pc to headed for a pcl and ended up with pcl-ag02 and the streams worked straight away.
let me know if you want me to wireshark the diffrent the gateways tomoro/today and see what they come back as.
Quote Well only diffrence from when i tried with out wireshark is i was on pte-ag1(i think) and changed to pcl-ag01 in beetween testing with wireshark
seems what i was seeing on tuesday wasnt me going
27-03-2009 10:02 AM
Please, can you also have a look at the traffic for browsing MLB's website (http://mlb.mlb.com/). It looks like they use the akamai network for their website too. All the html, and related scripts and images, are coming through with DS field of 0x60, which makes browsing that website (which I do quite a lot) fairly painful in the evening. Thanks.
27-03-2009 10:25 AM
Carl's going to reboot the e30 switches at Telehouse East to see if that improves the XBL traffic prioritisation.
Then he's going to look at mlb.tv again - he reckons it's not going to be that easy, because certain content will be delivered via Akamai, which will be difficult to separate.
Then I imagine, he might have a coffee
27-03-2009 12:02 PM
27-03-2009 3:13 PM
Just thought I'd comment on the iTunes Store again. I did a download last night, and it was very slow - 17 minutes per track, and the speed meter was reading around 3-400Kbps. It was also very slow loading the Store pages. Only a little while later, and well before midnight, I installed some Apple Updates, and they came at nearly 7Mbps. My router is connected at 8096/384Kbps (home wireless is at 270Mbps).
Cheers,
Andy.
27-03-2009 3:38 PM
27-03-2009 3:41 PM
We're trying to get a sig for iTunes from Arbor.
27-03-2009 3:48 PM
I'm guessing it means you are trying to manage iTunes better than other download protocols?
Regards.
Andy.
27-03-2009 3:51 PM
Because iTunes traffic is distrivuted by Akamai, it gets picked up as "download server" and thus rate limited at our end.
We've asdked Arbor Networks to find a way of differentiating iTunes traffic so that it will come down quicker for you guys.
27-03-2009 4:12 PM
Just one thought, on my system anyway, iTunes Store is much slower than other downloads at peak times. I can go to places like VersionTracker, or SourceForge, or download OS updates, and get good speeds (i.e. up to 6 or 7 meg.) at similar times of day that I'd use iTunes Store. I'm just puzzled that iTunes Store is so much worse than true 'download' sites, if they're all being treated the same.
Cheers.
Andy.
27-03-2009 4:13 PM
Quote from: Be3G However, it is worth mentioning that according to James only a subset of PN's products have got the new traffic management rules in place (a subset which doesn't include my BBYW1, hence the lack of testing from me), so perhaps you also aren't included yet.
iTunes has been looked at as part of the other work, currently only applied to BBWY2, Unlimited and Premier 1. The stats look good so hopefully we can roll to other products next week.
27-03-2009 4:25 PM
Quote from: Jameseh Not true at all Thomas.
I know that James, you said that a week or so ago... but when I then asked a further couple of questions, they seemed to fall on deaf ears. However, you may have answered them with this...
Quote from: Jameseh Because iTunes traffic is distrivuted by Akamai, it gets picked up as "download server" and thus rate limited at our end.
...so I'd just like to clarify, are PN intending to speed up iTunes downloads, or just streaming - and if the downloads are sped up, what speed should we expect to see for them (i.e. line speed or something else)?
27-03-2009 4:30 PM
So we'll get it treated roperly first and then look at what sort of quantities of traffic we're seeing before taking further action.
27-03-2009 4:53 PM
27-03-2009 4:57 PM
