Slow Upload Speed
- Slow Upload Speed
Slow Upload Speed
02-08-2013 11:33 AM
I'm hoping somebody might be able to help me, for the past few weeks i've had very slow upload speeds. Here is some of the information i have on the problem.
Home > Thomson Gateway > Information
DSL Connection
Link Information
Uptime: 0 days, 0:19:31
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,236 / 6,048
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,048
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 52.67
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 23.5 / 40.5
SN Margin (Up/Down) [dB]: 31.0 / 16.0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 2 / 0
FEC Errors (Up/Down): 4 / 67,813
CRC Errors (Up/Down): 4 / 422
HEC Errors (Up/Down): 5 / 4,286
This is the result of my BT speed test
Upload speed achieved during the test was - 0.04Mbps
Download speedachieved during the test was - 5.18 Mbps
I hope this is enough information
Any help offered would be greatly appreciated. Thanks
DSL Connection
Link Information
Message 1 of 5
(820 Views)
4 REPLIES 4
Re: Slow Upload Speed
02-08-2013 12:25 PM
Is that upload actually 0.04Mbps
If it is are you sure you don't have any P2P running
Message 2 of 5
(460 Views)
02-08-2013 12:54 PM
Hello, thanks for your reply. I copied and pasted the figures from the BT website so its correct. I don't use any P2P sites. When i send an email it seems to take ages especially if there is any kind of attachment with it.
Message 3 of 5
(460 Views)
02-08-2013 1:00 PM
Is this the infamous 585v8 wifi?
(582n stats seem to include 2 lines of vendor info, one with BDCM)
Edit: dug up a link to the 380 replies long 585v8 wifi issues thread: http://community.plus.net/forum/index.php/topic,92497.0.html
Message 4 of 5
(460 Views)
02-08-2013 9:20 PM
Yes it is the 585 V8 router. Thanks for the link i'll have a read through it
Message 5 of 5
(460 Views)
